Home > Help Needed / General Tech Chat > hepolite pistons any good or what can i get +20 for under £250
mini.cooper998
Member #: 3772
Wigan
hi all im after a set of pistons +20 for my engine build and wondered what people can recomend for under £250.
engine spec will be up to 175-180 bhp.
any recomendations appreciated
Andy
Spend £300 on a set of cast omegas, and be confident they will take what you throw at them (all things properly set up that is)
assuming 1293 that is.
Edited by minimole23 on 17th Aug, 2012.
mini.cooper998
Member #: 3772
Wigan
cheers but everywhere i look cast omegas are over £400 for 1293 spec. where do i get them for that price.
cheers
Andy
Adam_R
Member #: 1938
near Dundee
From MED
http://www.med-engineering.co.uk/catalogue...istons-die-cast
As mini mole says and Adam, 310 delivered as for +20 10 CC dish
mini.cooper998
Member #: 3772
Wigan
are they good for 14+ psi
bennyy
Member #: 9037
Doncaster, yorkshire
14+10psi
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
mini.cooper998
Member #: 3772
Wigan
brilliant.
pistons ordered from med, 10cc dish.
cheers All
Andy
These omega cast race pistons have been proven running boost over 24 pounds of boost and power levels over 200+ BHP
mini.cooper998
Member #: 3772
Wigan
cheers, on there website it says mid boost. and the forged says high boost.
thanks
bennyy
Member #: 9037
Correctly set up these pistons are plenty good enough, Robert uses cast omegas at 230-240hp
When I bought a set years ago they told me they wouldn't recommend running more than 14psi on them. I've been running a minimum of 15psi ever since ........ *happy*
bennyy
Member #: 9037
I have run mine upto 19psi so far, and I plan to run 23/24psi, fueling/timing must be spot on though.
My cast omegas have takend so much abuse i feel like pulling them out just to congratulate them
