Home > Help Needed / General Tech Chat > engine cuts out when trying pull away however high the revs are
charlieb150
Member #: 9931
brighton
hi all need some serious help/ guidance with my engine
basically i have a 1275 metro turbo engine with new turbo hif 44 and t3 turbo
ive tryed a different distributer (59d)and coil rather than the duclier no different
could it be jet related ?
also if i rev it up when not underload it will rev turbo kick in etc then go to give it another rev and it dies and cut out
any tips or anything would be much appricated thanks charlie
bennyy
Member #: 9037
Doncaster, yorkshire
Dashpot oil? Or idle mixture?
Edited by bennyy on 20th Aug, 2012.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
sim_ou_nao
Member #: 114
Porto/Portugal
Do you use the "tee piece trick"!?
works for me http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
Pedro Silva
the turbo kicks in when you rev it? .. cool
Could be the common mistake with the plenum to carb gasket being fitted the wrong way round
charlieb150
Member #: 9931
brighton
hi benny the dash pot oils fine will check the mixture tomorow, sim-ou-nao what tee piece trick? and brett well yeah the turbo spins up obivously. will the gasket cause it to litrally just cut out when you try to pull away
sim_ou_nao
Member #: 114
Porto/Portugal
See the link.... http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
do you have a photo from your carb in the car?
Pedro Silva
charlieb150
Member #: 9931
brighton
i dont know how to add photos lol
yep it will usually idle for a while at least, then any kind of load and it will lean out and die ( usually on boost but since your getting boost with no load that should not be a problem *wink* )
sim_ou_nao
Member #: 114
Porto/Portugal
http://www.steves-digicams.com/knowledge-c...tobucket.html#b
Pedro Silva
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Are your photos in photobucket?.
Main Build
Upgrade to Turbo
nala56
Member #: 9661
If your pictures are in photo bucket
This is what your post should look like to put pictures on TM, to do this you need to go to photo bucket, hold your mouse over the photo you wish to show, click the second option down, then go back to post reply in TM, select the icon on the right that I have circled in red, when box opens paste your image in, and it should look like the sample shown..
Main Build
Upgrade to Turbo
Sounds like a possible arir leak. Check that the float bowl breather is blocked and that the part-thriottle lean off pipe has no splits (this is the most likely thing IMO).
