Home > Help Needed / General Tech Chat > Too tight??
Not John, this hose:
Opinions please. I'm thinking it's a bit tight. It was made to my spec's and obviously wasn't that cheep...
kcchan
Member #: 8853
Can you swap the banjo for a 20 deg one?
I would have to have another hose made as they are crimped on.
I've 'adjusted' the lower fitting slightly and that has taken the tension out of the hose.
kcchan
Member #: 8853
I was going to say other than a 20 deg banjo or adjusting the lower pipe, there isn't much else you can do. Since those parts do not move, you should be ok. Although, it can be hard to tell from just a picture.
eden7842
Member #: 8852
leicestershire
Carnt u get a wee tweek on the bottom stainless pipe just to help it out?
Looks tight but should be fine
just ease it round a little
wng691s clubby
Member #: 9252
Cleethorpes
is it kinked? if no should be ok
Done now needs redoing lol
Personally I'd be really pissed off, but probably shell out another £20 to get a longer one that would loop round a bit.
It is your brakes after all.
The only other thing I can see is to move it over by removing the clutch hose bracket.
I've bent the bottom fitting a bit and it's a fair bit better. Not under tension now.
Can't move the bias thingy as it's rivnuted in and I don't want to start drilling into the nice shiny metal...
I will probably get another made up at some point, cash to finish it is getting tight now. These where an extravagance, but I didn't want a load of wanky bent copper spoiling the engine bay.
Craigie-B
Member #: 9468
Wootton Bassett
Flol at "wanky bent copper"
Or you could find/make a male to female adapter. Obviously the male end will screw into adjuster and the hose screw into the female end. That should lengthen it by 10-20mm.
Andy don't be as tight as your hose, shell out and get another one, you tight sod..... lol
What's wrong with a pice of copper? you flash twat *hehe!*
jlay
Member #: 1742
essex
i like to be a little posher i use Kunifer stuff
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Still 75-80% copper*tongue*
jlay
Member #: 1742
essex
yeah yeah i know *smiley*
dig-mini
Member #: 9269
Rotherham
Get a new one don't scrimp now you are asking us when you already know so go but another lol
Craig
Good plan.
Nothing wrong with Copper, if you have the ability to bend it properly...
I will get one at some point, I just can't spare the cash at the moment. It's getting to the point where it's new hose OR an MOT...
That will break! Why not run the hose in a loop upwards from the MC? ( A longer one obviously.)
Andy, I have some Kunifer i might also have some ends if you want as a temp fit until you can get a new hose?
I will get another one, but for now it is low on the priority list.
Money needs to be spent on more important things, like replacing the rod with the funny shaped big end so I can get the engine built...
Where did you get that made? Carlton?
yes
tadge44
Member #: 2500
Buckinghamshire
Andy, cant you just get a little bit of "adjustment" on the plain section next to the banjo, just to ease the apparent twist/kink ?.
I'm going to give that a try. Tried with it on the car last night and nearly pushed the car of the stands.
Will put it in the vice later on and try not to ruin it...
