Home > Help Needed / General Tech Chat > advice needed quick guys!
1275_dan
Member #: 441
can i use my 1275 turbo lump,and whack the supercharger on it which runs 8/9si???
thanks
I would have thought it will be an ideal combination TBH.
The turbo engine is up to the boost pressure you plan in standard form as long as its not fucked!
The obvious usual things would be worth checking before you put it in, e.g. diff and gearbox condition, mains and big end shells, thrusts, new oil pump, central pick up pipe etc.
