Home > Help Needed / General Tech Chat > Wheel Stud
daveg79
Member #: 9579
Tadley, North Hampshire
So I need to get some new wheel studs after stripping the threads on a couple today. Turns out I have to different sizes in my front hub. Suppliers seem to have a 35mm version and then nothing up to 50. I want the slightly longer version of my two which is nearer 38mm. Any ideas? Picture of mine below.
My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970
Pretty sure the longer one is from a Metro
I might actually have one or two lying around in my spares box, I'll check in the morning (feel free to text me to remind me!)
There are two length of studs available for the front Mini drive flange.
Late 31mm (disc) and early 35mm (drum)
Edit* Oh, and bolts/ screws are usually measured as 'under head length' not overall length
Edited by Sprocket on 25th Aug, 2012.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Mini spares, use new ones for safety reasons..
Main Build
Upgrade to Turbo
daveg79
Member #: 9579
Got the 35mm from Mini Spares. Works a treat :)
