Home > For Sale > Bedroom Clearout :)
Craigie-B
Member #: 9468
Wootton Bassett
Okay so I need this stuff gone as I have no money left
All prices do not include postage & packaging and also either send paypal money as a gift or with enough to cover fees which you can work out here please:
http://www.clothnappytree.com/ppcalculator/
I am based in Wootton Bassett at the minute, however my girlfriend drives to and from coventry everyweek so if you are in the midlands you can collect there if you want to :)
Okay heres what I am selling:
MK1 Metro Turbo ignition system, complete with new dizzy cap and spark plugs. £SOLD
I bought this from a member on here last year when I was first starting out collecting parts, have gone megajolt since and so I am selling this:
Standard metro turbo camshaft. £SOLD
Removed from my engine, I personally havent run the engine with this cam in.
Exhaust side of standard T3, complete with elbow. £SOLD
Again came with my engine, only the exhaust side is present but comes with the elbow that bolts on.
Blue T-Piece 2x10mm ends and the spout is 8mm. £3
Was going to use to return water to the engine but where I planned to use it wasn't going to work.
Mini SPi Sandwich plate needs some attention. £6
Bought from R1minimagic on TMF but failed to tell me the condition of it,will need the spout either building back up or chopping off a bit, the part that goes on the cylinder head has a few lumps out of it could do with a skim - maybe okay, but I didnt want to chance it
6M of 6mm Nylon Hose. £30
Brand New, no kinks or bends in it.
Standard T3 Braided oil feed. £20
Brand new, no damage fits a standard T3 setup
Renault 5 GT Turbo Intercooler. £15
Some/Most of the fins are bent, I havent use it myself.
Mini Thermostat housing with brass pipe in top. £7
I think it was home made, could be ideal for someone to return the water from the turbo?
Standard Metro Turbo plenum. £SOLD
Standard unit, I havent used this so unsure of condition.
11 Blade Plastic fan. £7
Not broken, should work perfectly fine, removed from 998 Engine.
1275 Turbo Coil. £3.50
Used coil, came attached to the turbo engine.
Renault 5 GT Turbo T2 Elbow. £SOLD
Came with the T2 I bought, no cracks, threads are okay as well.
Transfer gear from crankshaft. £SOLD
No chips in the teeth, replaced due to buying a full set of drop gears.
Simplex Timing Chain. £3
Brand new, never used. Bought it then went duplex as I upgraded engine
Standard Electronic Dizzy. £SOLD
1989 Dizzy, came with the engine, will need a new dizzy cap. Unsure of condition.
Universal Air Filter. £5
The end of the filter takes a 3" pipe, can get measurements if you want.
Golf 20vt Intercooler. £25.
Almost Brand new condition, only a few bent fins nothing really noticable. Comes with the standard cowling however one of the lugs holding this on has been removed. Still holds though.
Renault 5 T2 actuator. £SOLD
Bracket is complete, standard unit from a Renault 5.
Volvo 480 Turbo T2 actuator. £10
Cut the bracket off, however the actuator hasnt been harmed. Could still be of use with a custom bracket?
Metal 6 Blade fan. £20
Brand new, has a few marks and scratches on it from where I fitted it to my engine and then was removed, not bent or anything like that.
Engine Steady Bracket. £5
Found this after i had replaced it! No cracks or splits, good condition, although a bit grubby.
Standard Engine Steady. £10
Came off of my 998, DOES NOT come with the yellow poly bushes, will come with 4 Brand New Rubber bushes.
Standard Oil Return. £7.50
Doesnt come with the metal pipe that goes between the feed and the pipe. No splits or cracks.
T2 Turbo Flange. £7.50
Brand New, Hasn't been modified or touched as I had another T2 flange which I used instead.
Unknown Bracket. £3
I cant remember what this was from, It was in with my altenator bracket. No cracks, good condition.
Clutch Cylinder with Metro Damper. £7.50
Removed from the turbo engine as the 998 one was still attached. Pipe looks home made, however its not split. No rubber piece with it.
Volvo 480 T2 Exhaust housing. £15
I dont know if this is any good to you guys, standard volvo 480 turbo exhaust housing. Has the wastegate built in, 1 of the nuts is missing for the exhaust pipe end and 1 of the bolts holding the clamps to the turbo got chewed up so I binned it.
Renault 5 Turbo core and compressor housing. £30
I'm pretty sure the core needs re-building as its oilly. There was no play in the wheels but like I said previously I'm pretty convinced its knackered. Comes with the compressor housing and the circlip to hold it in place.
Brake Servo Pipe. £5
Standard Brake servo pipe taken off of the manifold.
Standard Metro Sandwich plate. £10
Been powedercoated black, in really good nick. Can get a picture if you want one
All prices are ovno Collection from Royal Wootton Bassett or Coventry, postage will be extra ontop.
Craig
EDIT: Sorry forgot to say these items are for sale on other forums and on facebook groups aswell.
Edited by Craigie-B on 12th Sep, 2012.
mossy2a
Member #: 9751
Derbyshire
You have pm regarding plenum
Craigie-B
Member #: 9468
Wootton Bassett
Pm's replied to
t@z
Member #: 452
Chester, UK
you have a lot of shit in your bedroom; is there room for your bed lol
www.twitter.com/lilpinkiy
Craigie-B
Member #: 9468
Wootton Bassett
Not really lol, this is just the for sale stuff. Stuff I have bought to use fills up 3/4 of it haha, literally a walkway to the bed and thats it haha
Turbo_Jonesy
Member #: 9041
I will take plenum if not sold already.
Craigie-B
Member #: 9468
Wootton Bassett
plenum prov sold mate will let you know
Craigie-B
Member #: 9468
Wootton Bassett
Igntion Setup SOLD
Plenum Chamber Provisionally Sold, awaiting payment
Your bedroom must have been a pig sty! Lol
Craigie-B
Member #: 9468
Wootton Bassett
still is haha
mossy2a
Member #: 9751
Derbyshire
Craig,
I've sent paypal payment but when I was doing it my phone went crazy . I've since sent payment again. Hopefully you've got it or if your lucky you've got double. lol
Let me know.
David
Craigie-B
Member #: 9468
Wootton Bassett
Got your payment David, only 1 of them.
Plenum Chamber SOLD
charlieb150
Member #: 9931
brighton
If the primary gears for 1275 a+ and the bushes are good ill have it :)
Craigie-B
Member #: 9468
Wootton Bassett
pm'd
Craigie-B
Member #: 9468
Wootton Bassett
most of this still available:
Metro ignition setup sold
Leccy Dizzy sold
Plenum Sold
Craigie-B
Member #: 9468
Wootton Bassett
Need all of this gone guys make an offer
Craigie-B
Member #: 9468
Wootton Bassett
All of the following is now sold:
Metro Ign System
Camshaft
T3 Exhaust Housing
Plenum
T2 Elbow
Primary Transfer Gear
Electronic Dizzy
T2 Actuator
Feel free to make offers on any of the remaining stuff
