| Home > Help Needed / General Tech Chat > Metro 4 pot brake bleed sequence | |||||||
![]() 55 Posts Member #: 9624 Advanced Member Seattle, WA USA |
4th Sep, 2012 at 03:20:48pm
What is the sequence for bleeding the metro 4 pot brakes? I have them on my Clubman and trying to get them bleed so I can drive it. 1991 mini cooper
4th Sep, 2012 at 04:23:05pm
bottom then top nipple, starting with the calliper nearest the master cylinder. On 11th Feb, 2015 robert said:
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
4th Sep, 2012 at 10:19:00pm
i has to do the inner and outer nipples at the same time to bleed mine took days to get them right Done now needs redoing lol |
6th Sep, 2012 at 08:18:56pm
ok I will remember next time. I took it to a shop this time. It was the last thing to do before getting it on the road. 1991 mini cooper
6th Sep, 2012 at 09:11:51pm
On mine it makes no difference which nipple you bleed from first. As long you can expel/bleed the fluid out at as high a pressure as you can is what you need to agitate the fluid and shift bubbles ect ect.
Own the day
7th Sep, 2012 at 10:54:15am
They are separate circuits top and bottom. On my blitz one pair are brakes and the other a hydraulic handbrake |
7th Sep, 2012 at 10:59:16am
On 7th Sep, 2012 jamie@thefatgarage said:
On my blitz one pair are brakes and the other a hydraulic handbrake I don't imagine this being much good for even pad wear?
7th Sep, 2012 at 11:03:13am
No, but it doesn't do any mileage, and it's only the rear brakes. It's the easiest solution when using a front subframe and hubs at the back of a kit car.. |
7th Sep, 2012 at 11:24:15am
I would have thought that a set of drums would be more suited? A hybrid of drum front hubs with the rear drum backplate, so you get hydraulic braking plus cable handbrake?
7th Sep, 2012 at 12:22:16pm
Maybe, I'll see how it goes, it came with the 4 pots already fitted.
