Home > Help Needed / General Tech Chat > Metro challenge turbo
turbo22
Member #: 3684
wisborough green west sussex
Hi guys,
Bit random but does anyone know what turbo spec these use to run. I know they were T3's but were they modified at all?.
cheers
The regs are available if you do a search for mg metro challenge cup.
A quick look suggests a standard or str unit. Some minor alts are allowed to the manifold
turbo22
Member #: 3684
brill thanks Rob, tried a search on here but no luck.
ta
The challenge cars run a stock t3, they only run about 8psi anyway.
Aren't they using a bigger exhaust housing? RS Turbo?
I think they are allowed to run the 0,35 turbine because the 0.25 is NLA
welshdan
Member #: 1111
s wales
Just a query, would there be any point in upgrading to this spec on a road car, hopefully running 18psi plus?
In short YES!
