Home > Show Us Yours! > ID my pistions hellp wanted
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
as above i need help to ID my pistion 1098 +0.040" i know its a 40 over as i can make out 040 on the top but i cant see anything else that i see as helpful
also best place to start a build log/place to post for help whilst building a turbo motor?
Not sure what they are, but they certainly don't look like they'd stand up to much boost.
Big oil slots and 4 rings will make them very weak.
As above don't use them for forced induction.
Officialy the largest oil slot i have ever seen..
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
ok well that's that this set of pistons will be set aside.. just for sihts and giggles i measured the slots they are about .060" (1.52mm)
what would you guys suggest? something that's been proven time and time again?
back to the other question where is the build log posting section? or am i in it?
Hypatecs I believe.
t3gav
Member #: 229
Gavin@minispares.com
kent
I'd guess at 12G758's but as you're not using them it doesn't matter now lol, you're in the right section :)
Youre in it
Anyone else know of any decent 1098 pistons for turbo use?
I can't seem to find any dished 1098 pistons which don't have oil slots.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
thanks guys i shall post a build log/advice thing soon
how about some but not sure if they are 1098cc or what?
http://www.med-engineering.co.uk/catalogue...ast-pistons-040
or not sure on the dish size
http://www.minisport.com/mini-spare-parts/...ished_Type.html
The MED pistons are big bore (1275+)
Not sure on the minisport items but I wouldn't count on the picture being of the exact item.
They look like the old 20773 piston, but as above looking at the rings they are most likely Aus Mini sport Hypertecs. Looking at the link below they 100% are.
http://www.minisport.com.au/prod1889.htm
I've had a set of these in the sprint (998 variety) and I've not been impressed.
MS Aus also seem to have a set of Mahle 1098 pistons which look the same, but a bit different. No large oil slot for one.
http://www.minisport.com.au/prod1171.htm
Edited by wil_h on 7th Sep, 2012.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
the mahle do how ever have the slot in the oil grove no good?
surely someone running a turbo 1098 is using something decent ish no? maby limit the boost?
i do have a tenancy to give the mini a lota stick and then some more and well some more...
