Home > Help Needed / General Tech Chat > whats needed to build a high reving turbo motor
mini.cooper998
Member #: 3772
Wigan
as the question says, ive heard that turbo motors are quite low reving before out of puff. but i just wondered what is needed to build something with a good long rev range.
thanks
Andy
also AVR sell 2 phase 2 cams one billet one reprofile. am i right in thinking the reprofile is just a standard cam built up and then re-profiled in phase 2 lobe spec, if so whats wrong with that as its £110 cheeper.
Thanks
Its all about the cam ohh and a god like turbo..
in short! a well ported head and race valves, etc .... a 998 engine and say a MG n/a cam timed in a little late. maybe a T3 turbo to give it some legs....... the combinations are endless!!!!!
the diffrence of the phase 2 cams are one is reprofiled from any old doner cam and ones made from a billet peice of steel and ground 100% accurate ...
bennyy
Member #: 9037
Doncaster, yorkshire
An engine and turbo makes a good starting point, and big balls.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
turbo choice is critical here,
yiu wan somthing big and efficient, that will maximize boost vs turbine pressure, as with a long cam turbine presure will kill the power from pumping loses on a small turbo.
How high is high?
http://www.youtube.com/watch?v=mLl2fK-fBbI
Oooo 8k is a bit of a screamer...
Iirc I read somewhere the don has seen the wrong side of the 9k line?
Edited by gr4h4m on 6th Sep, 2012.
yeah, rev limit 9200rpm iirc.
It is because of the don that for my next engine I will be going for a force racing prepped a plus crank. If the don ain't bust it I doubt I will!
According to the tell tale in the ECU the DON has actually seen more like 9500 at some point.
