Home > Help Needed / General Tech Chat > MAP Sensor Adaptor and 2BA Thread
tmsmini
Member #: 7637
Fremont California
I am looking to make an adaptor for a Rover MPi MAP sensor to use with Megasquirt.
The Megasquirt I am using is actually a Microsquirt and needs an external MAP sensor.
I know there are probably easier ways to do this, but... I have several of the MPi sensors already. And it seemed an easy method at first.
I bought some of these for the various carbs I might use
I thought I could just take one of the extra brass adaptors and thread it into a small aluminum block to make the adaptor for the Rover sensor:
as it has about a 10 mm male part that fits into the MPi intake.
The probem I have run into is that these brass adaptors use a 2BA thread and there is no close match metric or SAE. It is close to 10/32, but is loose and will leak if I drill and tap a 10/32 hole.
Anyone have a source for other threaded vacuum adaptors besides:
http://www.speedograph-richfield.com/html/..._pipelines.html
Terry
Johnny
Member #: 6926
Accrington
http://www.ebay.co.uk/itm/Brass-90-Degree-...#ht_2080wt_1397
http://www.ebay.co.uk/itm/9mm-Thread-x-8-6...#ht_1870wt_1397
http://www.ebay.co.uk/itm/7-25-Barb-Adapte...#ht_1563wt_1163
http://www.ebay.co.uk/itm/Hose-Tube-Brass-...#ht_1130wt_1163
any of these?
usually you will find this sort of barbed adaptor in a gas fittings shop etc
tmsmini
Member #: 7637
Fremont California
Yes any of those might do with the right size. I will just have look for something other than automotive applications. The ones from speedograph do have a restrictor, but that may not be necessary.
Also trying to figure out if I need a fuel trap in the line.
Terry
tmsmini
Member #: 7637
Fremont California
I guess what I need is a smaller version of this:
http://www.ebay.com/itm/VMS-6-VACUUM-INTAK...=item3a75378841
or this:
http://www.uprproducts.com/mustang-billet-vacuum-block.html
or just the fittings. I was looking for something smaller but 1/8 NPT should work for me if it works for these.
I may be missing something here. But is that MAP sensor not intended to be mounted direct to the inlet manifold somewhere? And if so surely it would be easier to have a flat area milled onto the inlet and then drill/tap a couple of holes to bolt it on?
tmsmini
Member #: 7637
Fremont California
Either there is method to my madness or just madness in my methods.
This is a development engine for me to learn about MS and AFRs etc. It is an MPi block and I wanted to try multiple carb setups, single and twin. So I thought that using the spacers with the vacuum ports would let me make manifold swaps until I throw the Rover FI setup on. I thought that the vacuum manfold like adapter would let me eventually let me mount the MAP out of the way some where.
I think some tubing and a reducer will let me get started playing without over engineering the setup at first.
