| Home > Help Needed / General Tech Chat > 7 port head, with high comp - wants to run SC without machining head...... | |||||||
![]() 117 Posts Member #: 9966 Advanced Member Norwich, Norfolk |
14th Sep, 2012 at 09:54:19am
Hi All,
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
14th Sep, 2012 at 10:01:37am
What is the current comp ratio ?
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
14th Sep, 2012 at 10:07:54am
i would go a sprintex supercharger.
Edited by NickG on 14th Sep, 2012. |
14th Sep, 2012 at 10:09:15am
Pistons will do the trick,
14th Sep, 2012 at 10:22:05am
Thanks Tom - seems pistons is the way to go.
![]() 580 Posts Member #: 9580 Post Whore Surrey |
14th Sep, 2012 at 10:49:37am
I use a copper plate I had made instead of the de-comp and 2 gaskets (equivalent thickness). Assembled it with sealant and runs 146 bh no problem. |
14th Sep, 2012 at 10:54:01am
accralite used to do pistons in these types of sizes. last time h had contact via omega they would only produce them in runs of 5 sets. minispeed look to do their own fi pistons, not sure if anyone had tried them on here, i cant comment on what they are like as i too have not used them. |
14th Sep, 2012 at 10:57:20am
Get some 11cc omegas. They sit 0.040" down the block, so you can deck the block to suite your target CR. On 11th Feb, 2015 robert said:
14th Sep, 2012 at 11:17:06am
Thanks guys, all very helpful and relayed back to the man with a much bigger budget than me!
14th Sep, 2012 at 11:19:15am
On 14th Sep, 2012 apbellamy said:
Get some 11cc omegas. They sit 0.040" down the block, so you can deck the block to suite your target CR. How much extra CC would 0.040" get you? I'm crap with numbers.
14th Sep, 2012 at 11:29:29am
Possibly speak to sc as well they may have developed a form of there twin cam sc kit, rough numbers on there 1310 with a stock head and lt cams produced 115bhp and with there sc conversion it went up to 194bhp according to there site also have aome running 240+bhp Drives
14th Sep, 2012 at 11:34:39am
With my build. A 28cc head, 0.020 cast omegas and standard deck height I worked it out to 8:1. With 0.030 removed from the deck height I got 8.3:1.
14th Sep, 2012 at 11:36:31am
Get some 11cc omegas. They sit 0.040" down the block, so you can deck the block to suite your target CR. 11cc won't get it low enough for forced induction. See my calcs above. 15 or 18cc needed, I'd say 9.3:1 would be OK with a supercharger so long as it isn't an oversped M45 which just turns into a heat pump.
14th Sep, 2012 at 11:38:58am
Thanks Andy |
14th Sep, 2012 at 11:39:15am
What deck height did you use Tom? On 11th Feb, 2015 robert said:
14th Sep, 2012 at 12:13:34pm
Firstly, don't bodge on an M45 onto this setup. Better to either turbo or maybe rotrex.
14th Sep, 2012 at 12:22:51pm
Ok so general consensus is the M45 isn't a good option?
14th Sep, 2012 at 02:12:47pm
The rotrex is a centrifugal pump (just like a turbo). But mechanically driven.
14th Sep, 2012 at 03:05:09pm
Thanks for the info Will, I'll look into it.
14th Sep, 2012 at 03:18:43pm
The unit fitted the the Mazda milenia in other parts of the world is a good choice, as is the sprintex unit - they occasionaly turn up on ebay uk. On 17th Nov, 2014 Tom Fenton said:
14th Sep, 2012 at 04:05:25pm
Toyota SC12 charger, rare as rocking horse shit though. Had to get mine from New Zealand as they never fitted them to UK MR2s. On 11th Feb, 2015 robert said:
14th Sep, 2012 at 04:08:11pm
What does he want from the engine, why is he so set on supercharging? A turbo set up should be easy on a 7 port. On 7th Oct, 2010 5haneJ said:
