Home > Help Needed / General Tech Chat > Carb Questions
Chalkie
Member #: 9764
Northamptonshire.
hey people
Is a HIF44 to big for a 998 engine?
I need to over bore my engine and its going to have 1275 head and sw5 cam hopefully running 9.1 Comp ratio untill I can gain boost
will it be fine to use or will i have to use something else?
Thanks
Stephen
I guess you mean non-turbo'd?
It won't be optimum, but it will work.
By nature of the SU and the varying venturi size, cant really see any negatives from using a 44
Chalkie
Member #: 9764
Northamptonshire.
yeah non turbo with HIF44 carb on
should i drop and use my hs 4 for now then?
get a hif38
Chalkie
Member #: 9764
Northamptonshire.
On 15th Sep, 2012 apbellamy said:
get a hif38
I got a 38 aswell but needs a new jet and jet holder they are beyond fu*ked.
http://www.sucarb.co.uk/
Chalkie
Member #: 9764
Northamptonshire.
Thanks
would the HIF38 be better than the Hs4?
Yes
Chalkie
Member #: 9764
Northamptonshire.
Okay ill rebuild that then thanks
Ill save my 44 till I boost it
