| Home > General Chat > Brick wall foundation depth, way OT | |||||||
16th Sep, 2012 at 12:28:21pm
How deep a foundation do you reckon for a 3 coarse high brick wall? I seriously doubt it! |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
16th Sep, 2012 at 12:38:25pm
copule inch of hard core and maybe 6 inch of concrete? Done now needs redoing lol |
16th Sep, 2012 at 01:32:28pm
it depends if you want it to move over time, the deeper and wider the base the more stable it will be in future,
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
16th Sep, 2012 at 02:06:25pm
it all depends on the type of soil you have. if you have loose soil then you may need to go down a fair way, but if it is hard/clay like soil you should get away with a shallow foundation. I would build it 300 x 150 and have 2 courses of brick work below ground level, then 3 courses above G/L and then back fill. The turbo build has finally started |
16th Sep, 2012 at 05:00:30pm
On 16th Sep, 2012 fastcarl said:
but big down 300mm and a 6" thick concrete strip 300mm wide will be fine, carl Thats pretty much what I did, ground is hard clay with loads of natural stone. Cheers guys I seriously doubt it! |
16th Sep, 2012 at 05:58:10pm
300mm depth on that should be more than enough. The turbo build has finally started |
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
16th Sep, 2012 at 07:15:27pm
10mm as can't be arsed to dig anymore |
16th Sep, 2012 at 08:17:04pm
mine has always been 9" |
16th Sep, 2012 at 08:44:40pm
On 16th Sep, 2012 philc said:
mine has always been 9" We are talking foundations here, not Piles On 26th Oct, 2004 TurboDave16v said:
![]() 478 Posts Member #: 9269 Senior Member Rotherham |
16th Sep, 2012 at 09:19:28pm
what's going on top of the wall and what is the wall for.
Craig
17th Sep, 2012 at 05:30:56am
Nothing ontop and its just to seperate patio area from grass area. I seriously doubt it! |
17th Sep, 2012 at 08:40:35pm
Just put it straight on top the ground 50mm of cement just to get it level why waste money on concrete and time for 3 coarse 225mm high. if you want you could turn some bricks the other way like they used too years ago on garden walls, but I wouldn't the wall is decorative that it. Craig
17th Sep, 2012 at 09:09:10pm
I assume the ground level is the same both sides of the wall? |
17th Sep, 2012 at 09:43:07pm
To meke a proper job, you need to excavate right down to bedrock, this rock needs to be at least 60 rockwell, if its not then you need to blast, keep blasting untill you find some of that black volcano rock, [fucking hard shit] then , and only then lay a 2M wide high strength reinforced concrete strip 600 mm thick, leave said strip to sure for 5 years to ensure untimate cured strength, [go to pub many times whilst you wait] then use 200nm concrete blocks in the foundation to bring up to ground level, once at ground level backfill, then leave for another 5 years to settle/compact. only now can you safelt lay the three course of decorative brick safe in the knowlwedge that you did the jod right first time around, .
17th Sep, 2012 at 09:47:27pm
150mm deep width of your shovel and leave the concrete down a bit to get a course or 2 of bricks below ground.
My build thread..
18th Sep, 2012 at 06:16:55am
Its a curved retaining wall, theres 200mm difference in ground level. The curve of the wall (62" radius) will give it strength, I did the foundation 8" wide x 8" deep. Ill get onto the bricks later in the week after building the decking frame.
18th Sep, 2012 at 07:15:10am
On 17th Sep, 2012 fastcarl said:
To meke a proper job, you need to excavate right down to bedrock, this rock needs to be at least 60 rockwell, if its not then you need to blast, keep blasting untill you find some of that black volcano rock, [fucking hard shit] then , and only then lay a 2M wide high strength reinforced concrete strip 600 mm thick, leave said strip to sure for 5 years to ensure untimate cured strength, [go to pub many times whilst you wait] then use 200nm concrete blocks in the foundation to bring up to ground level, once at ground level backfill, then leave for another 5 years to settle/compact. only now can you safelt lay the three course of decorative brick safe in the knowlwedge that you did the jod right first time around, . WORD!!! So this is why it took so long for you to build the wall in your back garden!! Now we know!!
18th Sep, 2012 at 07:51:00am
200mm retention shouldn't be an issue if the ground conditons are good |
18th Sep, 2012 at 07:57:27am
The ground is made up of around 7" top soil then rock hard clay with loads of natural stone. Took a whole day to dig out cos the spade wont go through cos of the stone.
