Home > For Sale > Swirl pot with loads of fittings
PaulW
Member #: 373
Leeds
For sale is as follows everything £130.00 plus postage.
-6 is the fitting size http://www.speedflowshop.co.uk/400-series-...-system-8-c.asp
1 x 1litre approx fuel swirl pot which has 3 x -6 and 1 x -8 connections
16 x -6 straight fittings
2 x -6 90deg fittings
4 x -6 (long) bulkhead fittings
1 x -6 to -8 adapter
4 x -6 to -6 straight connectors
5 x hex clamps 16mm(just fancy jubilee connectors really)*happy*
1 x -6 fuel filter (could be used as -6 or -8 if you use the adapter)
3 x -8 straight fittings
There is about 1.5 meters each of black and blue -6 hose you can have it but i would replace it if it was me. I'll remove before i send if you want.
There is some braided hose as in the photo again you can have it and its in really good condition.
Let me know if you want some better photo's
Paul
"I'll get there in the end"
