Home > Help Needed / General Tech Chat > brakes staying on!
NickG
Member #: 7912
Australia oi oi oi!
Hi guys so been driving my car around a bit testing it out.
all seems well dyno tomorrow.
one problem, the cars brakes! after a while of driving the brakes got better & better..
im like wow! great!! as the car has been sitting for 1.5yrs... anyways got better and better!
then bang the car slowed down & down!! I could not work out what the heck was going on, but the brakes are holding on.
picture me on the side of the ride trying to push a car that wont move haha.
I have a rover booster set up, with the master cylinder in one.
i had to crack open a bleed nipple to release some pressure & it fixed the brakes?
for now?
any idea? what is wrong? it's holding pressure but why?
shellspeed
Member #: 9580
Surrey
Had the same happen with mine. It was this
http://www.minispares.com/product/Classic/...ack%20to%20shop
Change the brake hoses.
NickG
Member #: 7912
Australia oi oi oi!
I just put new ones in
NickG
Member #: 7912
Australia oi oi oi!
i have one of them up the back. it's a moke type one, does the same thing.
got a spare rebuilt one.
that might be it, or the booster has shat it's self?
Check your brake pedal. As they don't move a lot, they can sieze up, especially if it hasn't been used recently.
Usually you can just remove pedal, clean it all up and put it back.
PITA job mind!
NickG
Member #: 7912
Australia oi oi oi!
can you grease them up will? bit of rubber grease on the shaft maybe? going into the booster?
It's the actual pivot of the pedal where it seizes, there is a bronze bush in the pedal and they get all shitted up.
I guess you could open a bleed nipple, squirt in some thin oil on th pivot and give it a good few presses. But I think it will only be temporary.
A strip down and a good polish of the shaft and some lube in the bush should give good relief.
Yo-Han
Member #: 3228
North of the Netherlands
Childish, I know... :)
Good advice though!
Edited by Yo-Han on 20th Sep, 2012.
Dazed and Confused....
shellspeed
Member #: 9580
Surrey
Bet me to it
Is it the front brakes, rear brakes, or all of the brakes ?
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Sometimes the caliper cylinders, part seize when the brakes have not been used for along time, so that they don't release off the brake disks..
Main Build
Upgrade to Turbo
evolotion
Member #: 83
Glasgow, Scotland
is it an after-market master cylinder like AP or similar? if so its not fully returning with the pedal released, and you either need to shorten the pushrod or space the master off the bulkhead by 10mm or so.
EDIT sorry just seen you say its the rover servo setup. in which case its ajusted wrong, or perhaps the wrong peddle? but most likely it just needs slackened off a bit.
Edited by evolotion on 24th Sep, 2012.
Denis O'Brien.
nala56
Member #: 9661
As above I had to adjust my push rod on servo/master cylinder to get the right amount of play at the pedal..
Main Build
Upgrade to Turbo
