Home > Help Needed / General Tech Chat > pre verto bolts to loctite or not to loctite
battleroc
Member #: 5620
Dunstable, Bedfordshire
Hi Guys,
as the title says really do you bother adding loctite to the bolts that go through the grey plate and flywheel?
Dan
TurboMike1992
Member #: 9928
Hartley, Kent
I would
Low boosting for now.
TurboMike1992
Member #: 9928
Hartley, Kent
Here's what happened to the taper on a turbo lump I bought that someone decided not to loctite.
battleroc
Member #: 5620
Cheers for this info guys...will 100% do it then..what grade do you suggest?
as I know the loctite has many diffrent codes for strenghts
TurboMike1992
Member #: 9928
Hartley, Kent
Well any decent thread lock of some sort.
Gotta be better than none.
battleroc
Member #: 5620
cool mike cheers
Amp
Member #: 7856
I may be incorrect, but I recall reading that if you add loctite, then the torque setting will have changed
TurboMike1992
Member #: 9928
Hartley, Kent
Just do it up to the torque of F T lol
I've never loctited anything clutch related and never had a problem.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
As Andy I have never used lock tight on clutch parts, done loads of mini clutches no problem, the problem with the one you bought Mike is was ill fitted on taper and not torqued up tight enough or lock tab not done right..
Main Build
Upgrade to Turbo
TurboMike1992
Member #: 9928
Hartley, Kent
Lock tabs were up so obv not torqued right, we had to chisel the boss in half to get it off! O.O
nala56
Member #: 9661
A long time ago in the years when you could buy a mini out of the news paper adds for 30 pounds, a runner or spares it used to say, I bought one of those and when i took the engine out and striped it down, I found some one had welded the flywheel onto the crank shaft, needless to say i scraped it because as I said, you could get the engines and spares dead cheap..
Main Build
Upgrade to Turbo
