Home > Help Needed / General Tech Chat > Spare parts after rebuilding carb!?
Craigie-B
Member #: 9468
Wootton Bassett
Just managed to finish rebuilding my carb, and I have a few spare parts left over!?
These are the spares from the original stuff:
These are the spares from the re-build kit:
I'm hoping that all the other spares are from the HIF44E carb and not mine!?
Craig
mossy2a
Member #: 9751
Derbyshire
Have you got a clamp fitted on the screw damper thing. It's a good idea to have one.
Aslong as yo replaced everything that came out its ok i did 2 carbs out my last rebuild kit thjnk i only had to reuse one throttle spindle seal
Craigie-B
Member #: 9468
Wootton Bassett
I replaced all the throttle spindle seals, and the choke seal.
I replaced the 2 rubber O rings on the choke spindle and also the 2 O rings on the float chamber and dash pot.
Replaced the jet, throttle spindle, throttle disc, throttle disc screws and the 3 screws for the dashpot and the 4 screws on the bottom for the float chamber.
I don't think there was anything else left to replace that was in the kit?
nala56
Member #: 9661
Sheffield South Yorkshire GB.
The kit you bought, to overall the carb with covers more than one model so you will have parts left over..
Main Build
Upgrade to Turbo
The round fiber washer is to go under the dashpot piston top, and the clamp is then fitted around that. I never use the clamp though.
The small metal clip fits on the top of the dashpot plunger to stop it falling out (You probably used your old one).
The small spring washers will be for the float bow screws or the dashpot screws.
The rest of the bits seem to be options for other carbs.
topcat
Member #: 9408
Tiptree, Essex
Don't think I've ever seen a dashpot piston clamp? What does it do and where does it go?
www.topcatcustom.co.uk
All the turbo carbs were fitted with them. It's supposed to stop the damper popping out. But it's overkill and not needed.
Craigie-B
Member #: 9468
Wootton Bassett
I was trying to find a picture of one online and couldn't find one :(
