Home > General Chat > Piston id
Scudy23
Member #: 10087
Very wet south wales
Wondering if someone could id these for me please, i bought them cos i was told they are 998 +0.20 which it states but are they ok to go in a turbo build ?
hard to tell from that photo. need a side shot.
But counting the rings and looking at the skirt length, I'd guess they were 20773s. Ok for 10psi.
Scudy23
Member #: 10087
They would be better than the flat tops tho ? How would i work out the compression ratio
Scudy23
Member #: 10087
Took a few more pics to help pin point these but inside is stamped 20773
ha, I'm king of the piston identifiers. Even say 20773 inside them.
As above, ok for 10psi, I ran them at 15psi wit hno issues (assuming fuelling and ignition was ll ok). They have a 6cc dish, so you don't need massive chambers, 24cc should give you 8.5:1.
If you are to use them you'll need to fit buttons rather than the circlips as these are the main point of failure.
Scudy23
Member #: 10087
Nice one wil
The plan is these with a 12g295 head ( slightly ported ) metro cam, glad they will do the job cos they only cost me £40 but i will replace the rings just incase.
