Home > General Chat > Automotive scope - choosing a bandwidth?
I'm thinking of purchasing a good scope (thinking digital storage scope via PC) that would have a good enough resolution for seeing the individual teeth on the crank pulley at 7000rpm...
For example: http://www.davecoxon.co.uk/CRANK_SENSOR.jpg
The frequency capacity is easy to estimate for my needs, but the minimum bandwidth needed to get a good resolution at that frequency is what I'm struggling to determine.
If anyone has used and got a good reccomendation on a scope, I'd like to hear it.
evolotion
Member #: 83
Glasgow, Scotland
would look into standalone units from uni-t. not quite agilent, but they have a good reputation, good following from enthusiasts, and cheap as chips. Cant comment on the bandwith issue sorry, tbo i dont thing iv ever bothered looking into it, automotive stuff is pretty slow in the grand scheme of things even a pc soundcard can be used to read trigger wheels at modest rpm.
Denis O'Brien.
For automotive, or general usage ?
For automotive, Picoscope is the one to have
I have a cheap USB Stingray scope. Ive used it at idle speeds and 2-3k, but not 7k. Dont see why it wouldnt work just fine though.
There are other similar scopes about if you search for them, probably better than mine. I bought it about 5-6 years ago although wouldnt use it that often
Weird that the trace in the picture shows the scope backwards, G-A rather than normal left to right.
Edited by stevieturbo on 1st Oct, 2012.
Nothing wrong with the trace
Except that it's backwards.
Even at 7k the frequency of the pulses will only be around 70Hz, hardly a fast wave.
To get rid of any ailiasing double that, 140Hz. As most scopes run at MHz you won't have a problem.
The analogue bandwidth quoted on scopes is the maximum siganal frequency it will measure. for automotive use you can get away with something quite basic.
We have a couple of these in work
Reason I asked, is that I've tried to use a scope and it would go down into the mhz range, but there just wasn't enough clarity in the trace to get a clean wave. That is the problem I was seeing - more of a "sampling rate" issue than a pure frequecy capacity.
I'd love to have the unit shown in the attached image once again (which is mistakenly labelled incorrectly of course) but I don't even remember what it was called, to start looking for one.
I'll look at the uni-t and picotech
Edited by turbodave16v on 2nd Oct, 2012.
I've found a fluke 123 locally for $300 (about 200 quid)... Although it's only 2 channel, it looks like it's a useful tool...
Doesn't look like it can be exported to the PC though.
Might go take a look however. Anyone have experience of these?
Surely 6000rpm ( easier maths *happy* ) is rotating 100 times per second. That's already 100Hz.
then say 36 teeth every rotation, that's 36 x 100 = 3600Hz. 3.6khz
Still not that fast really though
This is the one I have http://www.easysync-ltd.com/product/520/ds1m12.html
A standalone unit would be much easier to use though, but the big screen on a laptop and ability to record and view later are nice.
Stevie - that is interesting. Do you have any screen captures?
ah - just two channels, Damn. There is a world of difference from two to four channels in cost. Perhaps I should just have a rethink on what I really need.
Here's a snapshot trace of an early Subaru cam trigger. Probably around 1-2000rpm, cant quite remember.
2 wire magnetic, with 3,1,2,1 tooth pattern. I think I recorded them with a resolution of about 20us.
And this is a narrowband lambda trace working properly.
It's switching around 7 times per second. Ive zoomed so you can clearly see the trace. But you can easily zoom in so far on both that it almost looks like a horizontal line, or zoom out so it's just a scribble. So there really is plenty of resolution.
If you download the software I can email the files to look at yourself.
Edited by stevieturbo on 2nd Oct, 2012.
Mine is just one option. If you google usb scope there will be 4 channel or more versions of different makes.
I do rarely use mine, and because of that the logging software isnt perhaps as easy to use as I would like, but it's not bad really.
What about one of these ? Most are pricey except for the base version ?
http://www.bitscope.net/store/?p=list&a=list&i=cat+0
edit to add.
It's always worth searching Youtube as well ! just search for USB Scope and you'll get plenty of hits. People make videos of everything
evolotion
Member #: 83
Glasgow, Scotland
found a review for the DSO 203(quad) that showed sampling limitations at 150+khz
http://www.youtube.com/watch?v=Ajl21ne6JaU...D509F278EAB8843
This the sort of thing your referring to? sadly the dso's specs are well exaggerated, so you can use it as a ballpark for a samples/sec to give you an idea what you need :(
Denis O'Brien.
evolotion
Member #: 83
Glasgow, Scotland
A wee gem i forgot about, the Rigol DS1052E, can be soft-hacked to 100mhz. only 2 channel though.
Denis O'Brien.
jbelanger
Member #: 831
Montreal, Canada
You may want to look at this: http://www.ebay.com/itm/DSO3064-PC-USB-Dig...=item3371145976
I have no experience with it but it has 4 traces and is rated at 60MHz for 200MSa/s; more realistically if you use all 4 channels the maximum frequency is probably about 5MHz but it's not bad. It's only an 8-bit sample so it will be a bit rough. But it's not expensive and it has quite a few accessories.
Jean
http://www.jbperf.com/
Jean, I was seriously looking at the Hantek, but there seem to be so many quality complaints with their scopes that I just don't want to be spending money on something that might go poof...
I have just picked up a fluke123, so will have a play with that. Seems really cool, but definately not what I am really looking for.
jbelanger
Member #: 831
Montreal, Canada
Dave, where did you see these complaints? I have made a few quick checks on Google but didn't really see anything either on the DSO3064 or Hantek in general.
And that fluke looks nice but it is definitely not in the same class as the Hantek.
Jean
Sorry yes, divided by too many 60s. I thought it looked a bit low, but as you say, still bugger all.
On another forum this Hantek was recommended. Again only 2 channel and USB.
I'd say the hardware with most is less of an issue, it will be the user software that is most important which is why the Pico is so expensive. The software and the support for the product, because it is specifically aimed at car diagnostics, they have lots of info and traces to compare to if you're in that line of work.
http://geoffg.net/DSO2250.html
