Home > Help Needed / General Tech Chat > HELP
evilbutnice
Member #: 9174
colchester essex
hi all
just moted plus taxed the car and i think my turbo has just gone... it smokes really badly when its running and under boast it sounds like somthing it rataling from the turbo.. checked the head gasket and its fine i am not losing water just oil. dose any one know what this could be or is it just a new turbo???? if it is the trubo where can i get one from as avon bar is no longer..
many thanks darren
Edited by evilbutnice on 3rd Oct, 2012.
What turbo?
big_blue_bug
Member #: 9966
Norwich, Norfolk
A while back I had a T25 go on my 200SX - turned out the turbine shaft had snapped and was bouncing around in the housing.
Does it run well other than the smoke? or does it feel down on power?
evilbutnice
Member #: 9174
colchester essex
Car runs all right still boasts up ok just smokes really badly... It's a t3 turbo from
big_blue_bug
Member #: 9966
Norwich, Norfolk
what colour is the smoke?
evilbutnice
Member #: 9174
colchester essex
Gray
big_blue_bug
Member #: 9966
Norwich, Norfolk
White is water, blue is oil. Sounds like the head gasket may have gone.
I'd suggest starting with a compression test to rule that out.
evilbutnice
Member #: 9174
colchester essex
Yer I will do but I drove it for about 2 hours yest and dint lose any water the smoke cleared then got worse
big_blue_bug
Member #: 9966
Norwich, Norfolk
Well, you're burning something - hence the smoke. so its either water, or oil both of which can be from a blown HG.
if its only smoking on boost it could be the turbo needs a rebuild, or new oil seals. The turbo can leak oil into the exhaust downpipe which burns and produces smoke.
talking from experience (i'm still going through it) its a process of elimination. I'd start with a compression test, and taking the turbo off for inspection.
what does the noise sound like and where is it coming from?
evilbutnice
Member #: 9174
colchester essex
Forgot to say when it first started to smoke it was on tick over e.g when I stopped to a set of lights
eden7842
Member #: 8852
leicestershire
Tick ovet is normaly guides, id do a comp test and whip a boost pipe off to see if theres oil in there which would be turbo.
If you can hear a rattle thats most likely to say turbo,
Can you get the intake pipe off to check for play in the turbo?
evilbutnice
Member #: 9174
colchester essex
Right took it apart there is oil from the turbo into the inter cooler nothing going the carb and no oil out of the turbo to the exhaust.. I have the head off and there is oil in the pistions and the head gasket looks a little gone but from a water way to the pistion... Hope this helps
evilbutnice
Member #: 9174
colchester essex
a few pics
befor
Turbo needs a rebuild looking at the snail outlet. the oil in the bores and on the deck is likely to have come of the head when you lifted it of..
The burn in the gasket wouldn't cause the smoke problems.
Mike-998
Member #: 9774
Buckinghamshire
nice looking engine bay though, you've done well to get it all in, especially with the front rad and the alternator, is that an mpi one? or custom?
What intercooler is that?
big_blue_bug
Member #: 9966
Norwich, Norfolk
Yup turbo rebuild. I feel your pain!
Goosed Turbo seals especially. If the Turbo is some 20 odd years old and or unknown. ?
evilbutnice
Member #: 9174
colchester essex
It's only a year old turbo as it was a rebuilt one..
evilbutnice
Member #: 9174
colchester essex
If I do need one where can I buy a reckoned one from as Avon bar is not there no more? I brought this one from them 1 year ago... The other thing I am confussed about is there is only oil going in to the inter cooler not coming out the other side to the carb?
evilbutnice
Member #: 9174
colchester essex
So if it is the turbo dose any know where I can get a reckoned one from its a t3 garret turbo?
Any turbo reconditioner. Try yellow pages, or big names like turbo technics
That head gasket looks like the head is under torqued. Check your torque wrench.
http://www.youtube.com/watch?v=3t8MeE8Ik4Y
I have just realised lennon was the only good beatle...
