| Home > General Chat > Metal Chop Saw? | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
5th Oct, 2012 at 09:50:41am
Hi, we have 3 or 4 heavy duty saws which we can cut up to approx 12" solid round on, my problem is because they all get so much use they are not accurate for small bits and pieces.
www.topcatcustom.co.uk |
5th Oct, 2012 at 10:17:29am
Personally I have a small Clarke bandsaw, this is good enough for cutting to approx length, I then face stuff off in the lathe if it needs to be spot on and/or a good finish.
5th Oct, 2012 at 09:46:56pm
Pretty much all chopsaws Ive ever seen are the same. Simple metal base with a clamp. Wouldnt say any of them are precision items. Ive only ever used the normal cutting disc versions though. TCT one should be a lot better ?
5th Oct, 2012 at 11:33:34pm
I have a 255 rage tct mitre saw its supposed to do metal and wood no way will it do 40mm bar, however i am happy with it so far Crystal Sound Audio said:
6th Oct, 2012 at 09:59:49am
Good point...solid metal bar might be pushing things.
6th Oct, 2012 at 12:02:41pm
You get what you pay for. The cheaper ones will have a lighter weight chassis. If your looking for something more substantial, you'll need to look at the engineering tool suppliers |
6th Oct, 2012 at 08:53:20pm
Yeah we have a couple of slow pull down saws with coolant pumps which are very heavy duty, but not great for big solid stuff and the cut isn't great. I think a fast TCT saw is the way to go, we have a couple of band saws too, the big one will do anything at all, we have cut 250mm round solid bar before and the cut is ok, but on small stuff it's not great, also being a band saw the blade does wander slightly. www.topcatcustom.co.uk |
