Home > General Chat > turbo carbs
dutchman
Member #: 572
i am very new to this! how do i mod 1 3/4 su for turbo use? in south africa you cant buy any special mini stuff, so i am using mostly home made stuff.
I'll say it before anyone else does...
1) Welcome to the site!
2) Make use of the search facility!
3) You can reasonably easilly modify any HIF into 'Blowthru' spec. You've little change of getting the old HS carbs to work with blow-thru however.
Here is the plumbing side of it for you... Nice and easy there!
You'll need to source a plenum or make one - you'll find information on making a plenum in the 'How To' section - in fact - almost all your answers are in that section. http://www.turbominis.co.uk/forums/index.php?p=vf&fid=5
Yes welcome. Good Pic info Dave.
akirch
Member #: 399
Austria
Nr. 3 and 5 at the picture: "I personally block this pipe off".
Dave, I think here you have connected the two pipes (isn't it?):
http://www.netsnapshot.com/users/4541/imag...4GU_4541_42.jpg
http://www.netsnapshot.com/users/4541/imag...4GU_4541_43.jpg
Is there a difference between connecting and block off?
I also want to block off, because at Nr.5 is need the place for my new intercooler-pipe/plenum-construction.
Regards,
Andreas
Edited by akirch on 6th Jun, 2005.
http://www.minifreunde.at
Just because the pipe is present doesn't mean that it is connected.... *wink*
dutchman
Member #: 572
THANX FOR THE ADVICE. IM RUNNING (ONE DAY WHEN ITS DONE) 1275, 8CR T2 INTERCOOLER +-0.5 BOOST. FEULPUMP? & FEUL PRESSURE?
Fuel pump- either use the metro turbo type pump (available new, try avonbar or others) or use the injection fuel tank with integral pump from a later injection mini.
Fuel Pressure- set at 4psi with pump running engine off. Then with the correct turbo fuel pressure regulator you should see the fuel pressure stay at that 4psi above whatever boost pressure is.
Turbo Tel
Member #: 588
Delaware, USA
OOPS! looks like I replied to an old thread here...
Edited by Turbo Tel on 14th Dec, 2007.
...and that's my job!
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Yeah it is old, Macgiver looks a lot younger in Toms avatar.
On 7th Nov, 2008 Nic said:
naeJ
m
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Hi guys I know Im pulling a Vegard here but I was searching around on how to convert NA carb to turbo spec and found this post and most of the other posts refer back to this 1. Problem is I cant see any of the pics........ is it just me or it it cause its a really old post ?
Any help would be great
Dan
"Try to take over the world!"
Turbo Tel
Member #: 588
Delaware, USA
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=217478
pinkyandnobrain
Member #: 2588
Thanx Turbo Tel ! Cheers !
