Home > General Chat > GT17 Turbo Elbow
mossy2a
Member #: 9751
Derbyshire
I am currently in the process of making the adaptor plate and elbow for my GT17. I have noticed that the T3 elbow fits onto the outlet of the turbo, which on first indication looks like it should give me roughly the same height to connect the exhaust. some machining will be needed to adapt the elbow but doesnt look too much work. Has anyone tried this?? i have seen a few people make a plate flange and weld an elbow to it etc.
Just gauging weather its been tried and failed.
David
I'd may be interested in this if you could make it work.
mattsmadmini
Member #: 9965
Sydney, Australia!
my turbo is a little different, just a bent up 2" pipe with a slight flare and it will be the bee's knee's...
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
eden7842
Member #: 8852
leicestershire
I wuldent bother due to the fact you would then still have the t3 style downpipe and pain in the arse clamp.
Matts looks awsome!
Matts looks awsome!
Good point!
mossy2a
Member #: 9751
Derbyshire
I have found / stumbled across a clamp that i use at work, Stainless steel, single bolt v clamp, im hoping it will do the job. We use them to join flanges on pipework, the 2" one seems to fit ok.
a link, comments would be good, the one ive got is the heavy duty one.
http://www.google.co.uk/imgres?q=2%22+tric...7&tx=119&ty=105
David
steve1275
Member #: 951
Bromsgrove
I used a short section of tube flared at the end,with a loose ring drilled to fit on the turbine outlet studs for clamping.
'Where does the engine go?'
tadge44
Member #: 2500
Buckinghamshire
I just used the first 3" of a Saab down pipe tu achieve what Steve has done, above.
