Home > General Chat > de-seaming rear bumpper
ryandalby
Member #: 10141
york (UK)
hi guys
if got my new fiberglass front end with front splitter and it dosent take a front bummper so will look silly with a rear bummper so i was wondering is there anything special tricks or is it just
weld it from inside,
cut seam off and
smooth over.
thanks
ryan
mercenary62
Member #: 9937
hi mate youl need to cut it off on the outer lip ,but only 4 to 6 inches at a time , weld that up ,then cut another 4 to 6 inches and weld up and so on till its done ,dont whatever you do cut it all off in one go or youl end up in a real mess
give em hell
Scudy23
Member #: 10087
Very wet south wales
Woud that go for de-seaming other sections as well ?
Weld the rear vertical seams from the inside before you do any chopping.
ryandalby
Member #: 10141
york (UK)
which is best welding from inside or outside 4" at a time
Chalkie
Member #: 9764
Northamptonshire.
If your doing the outer seams do 2 inchs at a time
ryandalby
Member #: 10141
york (UK)
ok then but is it best to weld it from inside or outside????
I'd weld it from the outside as its easier to get to. Why complicate things? *oh well*
Chalkie
Member #: 9764
Northamptonshire.
Both Properly be alot stronger
Rick.SPI
Member #: 8027
You wont need both mate. The penetration fron one side will more than cover it.
A bumper is lighter than all of the filler you'll need.
ryandalby
Member #: 10141
york (UK)
hehe yeah a bummper will be lighter but it will look stupid with no front bummper but with a back bummper.
and thanks to all you guys id be lost without you all hehe.
thanks ryan
