Home > Help Needed / General Tech Chat > 7 port cam
All this talk about cams has got me thinking
Is there a better cam for the 7 port than the ph2? car has to be MOTable but still looking for something around the 200 bananna mark
if in theory there was somthing better but unavalable off the shelf i would happily have one made
thoughts??
Edited by wolfie on 23rd Oct, 2012.
ph2 was good in mine, as was the 266, and that's with 1.5 rockers.
I think with injection you wont need to be to worried about emissions due to the better atomosation.
what year emmisions do you need to meet?
thinking about it i dont as mine is a 69 still needs to be road drivable though
Pauls favorite 274 would be a good choice,
wide LCA to help with emmisions,
I'd be tempted to try something a bit more extreme to take advantage of the 7 ports and match the short intake runners.
Edited by Paul S on 23rd Oct, 2012.
I have read of a 276 on a 7port turbo, no idea where it was now but it made 203bhp iirc. surely for a road built motor a 274 would be at the limit of driveability?
nah,
the ph2 is 27 somthing, a 276 wont be that much worse,
The 274 is actually much, much tamer than the 276. Somewhere between the MG Metro and the Ph2.
Simon
Member #: 1865
Norwich, Norfolk
I have a 274 in mine that will be for sale as soon as I remove it from the block.
I reckon that a 276 cut on a 112 deg LCA would be good in a 7 port turbo.
If the turbo is big enough, say a GT25, then a 276 inlet with a 286 exhaust on a 112 LCA.
However, both would be pointless with the Metro exhaust manifold.
i have a gt20 on a tubular manifold Paul
Short middle runners kill torque/VE on the inner cylinders - even more than charge robbing. A long duration cam won't cope.
274 would be a good choice.
