Home > Help Needed / General Tech Chat > Hard spicer output shafts and cover endfloat
jamie@thefatgarage
Member #: 9345
Sheffield
Took off the diff side cover to replace gasket and (hopefully) cure mahoosive oil leak. Question: Is it normal for the endfloat of the output shaft to be 2mm or so and nothing to be between the circlip and the side cover? or am I missing a thrust washer or some other widget?
There should be a steel washer, about 1.5mm thick. Endfloat doesn't matter
http://minispares.com/product/Classic/Gear...k%20to%20search
jamie@thefatgarage
Member #: 9345
Sheffield
A cheap fix for once. Thanks for the info chaps.
