| Home > General Chat > Yellow flo-flex poly bushes | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
1st Nov, 2012 at 12:04:16pm
Hello guys,
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
1st Nov, 2012 at 12:53:05pm
Not heard of floflex. Where did they come from?
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
1st Nov, 2012 at 01:59:53pm
For them to be too flexible they must be awfully soft- can't see how any poly type bushes are more soft than rubber?
www.topcatcustom.co.uk |
1st Nov, 2012 at 02:28:16pm
When the car gets jacked up the floor mounts on the front subby do flex and you can get your finger in between them and the floor pan.
1st Nov, 2012 at 03:00:52pm
Think iv bought a set of these, hope they arnt the same :/ |
1st Nov, 2012 at 03:53:09pm
Andy bought a set aswell.
2nd Nov, 2012 at 11:43:26am
IMO solid subby mounts are the only way forward. On 28th Aug, 2011 Kean said:
2nd Nov, 2012 at 11:52:31am
Yes I wish I knew this before buying the yellow bushes, would of bought the much better ones If I had known
2nd Nov, 2012 at 12:44:38pm
On 1st Nov, 2012 Craigie-B said:
2nd Nov, 2012 at 03:25:30pm
Dammit seems like iv thrown £50 down the pan |
2nd Nov, 2012 at 05:01:22pm
Why fit poly, when rubber is soo much better?? Yellow bushes are gay/chav. On 13th Jul, 2012 Ben H said:
2nd Nov, 2012 at 05:29:45pm
I fitted poly because its supposed to be an upgrade? Plus it wont have broken down in a short space of time like rubber On 10th Mar, 2012 theoneeyedlizard said:
2nd Nov, 2012 at 05:36:38pm
As jo says solid. Just bite the bullet and change them.
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
2nd Nov, 2012 at 05:43:57pm
On 2nd Nov, 2012 Vegard said:
Why fit poly, when rubber is soo much better?? Yellow bushes are gay/chav. The rubber bushes I put on my rear frame lasted 1 year parked up plus 20 miles towed on an a frame before they perished and split. Total waste of time unless they are made with the correct rubber in the first place. On 11th Feb, 2015 robert said:
2nd Nov, 2012 at 06:05:27pm
Same with my landy. Fitted poly bushes and were crap, failed MOT on them a year or 2 later. www.topcatcustom.co.uk |
2nd Nov, 2012 at 07:33:31pm
Why fit poly, when rubber is soo much better?? Yellow bushes are gay/chav. The rubber bushes I put on my rear frame lasted 1 year parked up plus 20 miles towed on an a frame before they perished and split. Total waste of time unless they are made with the correct rubber in the first place. i had to change almost all my bushes before doing any miles, spent alot of money looking for new old stock, seems to have done the job
Yes i moved to the darkside |
3rd Nov, 2012 at 07:50:07am
Solid mounts should be here in next day or two or three as its weekend.
pluss yellow was cheap would have gone for purple powerflex if Id known
