Home > Help Needed / General Tech Chat > throttlebodies bmw f650 gs
Bill
Member #: 10080
Holland, Eindhoven
Is it ever been done 2 bmw injection(with the throttlebodies) of the f650gs together with a m45 supercharger?
I wanna build this but im not sure if this is possible (room)with a stock cilinderhead.
And megasquirt for the software?
Kind regards
Bill
Not heard of it. But they're just throttle bodies. Are you planning on putting them before or after the SC?
Bill
Member #: 10080
Holland, Eindhoven
after the sc
Bill
Member #: 10080
Holland, Eindhoven
blow through set up
i looked at doing this a few years back with ducati tb's then decided the gains were not worth the expense over the su
I presume you are not planning on using siamese code?
You are basically building a wet manifold injection system. The most successful wet manifold systems us a single TB with 2 injectors. Using a TB for each port has been done, but IMO the single TB is a better solution.
Bill
Member #: 10080
Holland, Eindhoven
Thank you very much for the answers.
So I have a turbocarb. already here, so you wouldn't change it to injection to get better fuel milage? Because that was the main intention. And I still need or megajolt or megasquirt. So that's why I was thinking of this solution.
Please give me some advice what to do?
Maybe it's way to complicated for me(I'm a grower)
its been said that i am a grower also *wink*
jamie@thefatgarage
Member #: 9345
Sheffield
If economy is your only motivation then consider that by the time you'd paid for all the gubbins for injection you'd have to do more miles than Captain Picard to get the money back in fuel savings.
Bill
Member #: 10080
Holland, Eindhoven
Year I'm from Holland!
I will listen to you all and put my carb in it.
Thanks for all the advice
If you're after fuel economy, bin the SC, and fit a turbo. even the best setup SC will only achieve 25mpg
I hope to prove that wrong. *smiley*
26?
It's still better than 25 *wink*
