| Home > Help Needed / General Tech Chat > camber and tracking on rear | |||||||
![]() 580 Posts Member #: 9580 Post Whore Surrey |
6th Nov, 2012 at 12:19:35pm
Gents
6th Nov, 2012 at 12:26:59pm
1.5mm toe in
6th Nov, 2012 at 01:24:23pm
camber - http://www.moss-europe.co.uk/Shop/ViewProd...teIndexID=17761
6th Nov, 2012 at 02:42:49pm
Nothing beats these for cheap and accurate tracking setting.
![]() 520 Posts Member #: 189 Post Whore Norway |
6th Nov, 2012 at 02:51:37pm
On 6th Nov, 2012 Vegard said:
Nothing beats these for cheap and accurate tracking setting. http://www.longacreracing.com/catalog/item...?id=152&catid=5 I use an even cheaper solution with 2 homemade identical wood boards held in place with bungycords and a 2 m ruler. Its not as posh as the Longacre's tho :) www.shag.no |
6th Nov, 2012 at 04:48:32pm
Think I have sussed it - Because you are only swinging around a fixed point (outside of the radius arm), once the camber is set and I bring the arms both in (or out ) and the readings between the front of the board and the rear match they are in line.
Edited by shellspeed on 6th Nov, 2012. |
