| Home > Help Needed / General Tech Chat > found another broken piece | |||||||
7th Jun, 2005 at 12:31:47am
7th Jun, 2005 at 07:13:24am
It would be the bolts that hold the cam plate on I would have guessed, but you say there is no wear on them?? Double check? And was the cam endfloat OK??
7th Jun, 2005 at 11:56:06am
if there is no wear on the parts you described budd
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
7th Jun, 2005 at 03:35:08pm
i had clearance problems with the cam retaining plate bolts, design flaw afaik.
Edited by andeh on 7th Jun, 2005. I've seen the future and tbh its Pie
7th Jun, 2005 at 04:58:43pm
had a closer look at all the fixing bolts etc, and its been catching on one of the cam plate bolts. feckin things.
7th Jun, 2005 at 05:18:38pm
Personally - I'd machine the pulley - Fit and forget solution! On 17th Nov, 2014 Tom Fenton said:
7th Jun, 2005 at 06:03:01pm
Bud the bolts are 1/4" UNF. A good source of countersunk screws would be the ones that hold on the rear brake drums on the late type spacer drums! You want 1/4" UNF by approx 3/4" long, have a measure though, that is just a guess by me. Also, countersinking the holes is not a great solution, as the cam location plate has slightly oversized holes to allow it to move SLIGHTLY before it bolts up tight. By countersinking them it will only then bolt up in one place. As Dave says, best way to do it is m/c a little off the area in question. The other thing you could do is machine a little 'depth' off the bolt heads also?
Edited by Tom Fenton on 7th Jun, 2005.
7th Jun, 2005 at 06:49:52pm
why didnt i think of just machining the pulley instead of the bolts...d'oh
7th Jun, 2005 at 07:30:25pm
If you put it on a lathe as an assembly, and just flash off the damage, it'll be good as new (but better, in that it'll fit On 17th Nov, 2014 Tom Fenton said:
7th Jun, 2005 at 09:23:37pm
cool, i was hoping it'd work like that.
