Home > General Chat > Compression ratio check
welshdan
Member #: 1111
s wales
Hi, I’m about to start building my new engine. I am taking the block for machining this week, I was wondering if anyone could cast their eye over my compression ratio calcs?
1380 bore
18cc pistons
0.8cc ring lads
3.8cc bk450 head gasket
25cc chamber volume
? cc deck height
The pistons are forged accralite, I understand that these sit aprox 40 thou down the bore on a standard heck height. The block I have has almost certainly been skimmed on the deck previous. I will have to build the block up once it has been overbored and measure the deck height properly.
With a deck height of 0 I make the compression ratio 8.25
10 thou – 8.1
20 thou - 7.96
30 thou – 7.82
40 – 7.7
I will measure the actual height on a dry build when I get the block back and get the block faced to suit.
Do these calculations look about right? cheers, dan
yep thats about right,
I'm on a 1380 with 18cc psitons, and a 24cc head and mine is about 8.3 ish
welshdan
Member #: 1111
s wales
cheers joe. what deck height are you running? cheers, dan
about 5 thou
welshdan
Member #: 1111
s wales
great. im hoping to run at around 8.0 - 8.1, but will have to wait and see what the current deck height is. cheers, dan
Craigie-B
Member #: 9468
Wootton Bassett
did you machine the 1380 pistons to 18cc yourself?
welshdan
Member #: 1111
s wales
no these are forged accralites. that how they came. i believe that omega will still make them but only in batches of 3-4 sets minimum. cheers, dan
