Home > General Chat > OT Generators
I have been givin a kawasaki ge2200a generator today I was told if I could get it going I could have it, so some new fuel and a new spark plug it fired up, so far so good, then I plug some stuff in to see if it would run them I was working my way up to the compreeser when it just stoped working. The 110v side is still working so I am not sure whats going on anyone got any ideas??
simon.
does it have an overcurrent trip on the 240v side simon ?
yes mate there is 2 little ones i have had a play but no joy. do you think i could of killed one of them? as i only what the 240V side to work.
Kean
Member #: 341
aka T2clubby
South Staffs
Pop them out and do a continuity test across. If they won't reset you may have fried them with too much load, what were you running?
I just pluged in my big air compressor, thats when i went.
got it in one only one has continuity
on the basis of your model numbers, the generator is rated at 1700w; a 3hp sip compressor motor is rated at 2200w. probably doesn't answer why it wont reset but probably answers why it tripped in the first place
OOO i see thats not good, I am a dick sometimes,, if i can get this working it would be great as its only cost me £5 in fuel and a old spark plug so far.
still a bargain so far
shellspeed
Member #: 9580
Surrey
I would say 8 amps is about your limit. We had a similar size genny when we went racing and it would not boil a kettle - very poor show!
What you think i should, go looking for a new trip for it? or see if i can swap them over? the guy that give me it said that it will run a kettle.
with my limited experience, it should run anything up to a load of 1700w; would be good for lighting, chargers and power tools
heres a pic of the bad boy.
yup , i think a compressor was aking a bit much simon ,can you swap the 110 breaker into the 240 side , is it the same bit of kit ?
yes it looks the same, i will have to get the part nub and see how much they would cost for a new one.
well i have just had a better look and there both have the same part number AC250, K76 also has 3J13 on there.
looks just like this one.
http://www.ebay.co.uk/itm/Kawasaki-GAT00-G...=item23241f0cd1
do you think i could fit this sort if i find the one right one ?
http://www.ebay.co.uk/itm/GENERATOR-CIRCUI...=item20cc9c203c
Edited by madmk1 on 15th Nov, 2012.
mercenary62
Member #: 9937
seems like a lot of work to boil a kettle, do it up and sell it on mate ,go for good money on ebay
give em hell
oli79
Member #: 8480
A normal kettle is around 2kw, when we used to use genny's onsite we used travel kettles or they do low wattage camping kettles around 1kw, they take about 10 mins to boil though! Another thing to note obviously a site gen so not great for computers/anything electronic there are inverter gens for a smooth output for that sort of thing.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Its for my lock up mate, so i can run prower tools lol.
mercenary62
Member #: 9937
ah got you mate lol ,yeh handy for a lock up situation
give em hell
you can now look out for some cheep 110 power tools as well
Well i have swaped over the breakers and still No 240v*frown* 110v still works so i am lost now.
