Home > General Chat > Hillclimb and Sprint Engine Rules
carl talbot
Member #: 1323
At Last !! -
After 8+ years of lobbying , petitioning and general ranting -
From 2013 you can run a Mini in the over 1400cc Class in Modified Production Cars
As long as the engine block remains outwardly same as production , then any capacity NA or Boosted is OK !!
*happy*
Thats gonna speed things up a bit, though I'm guessing traction off the line will be an issue!
Ben H
Member #: 184
Melton Mowbray, Pie Country
All you had to do was ask the right person! This is good news though. So will you be getting the minor back out with a K headed turbo monster?
http://www.twin-turbo.co.uk
carl talbot
Member #: 1323
absolutely .
prob. not next year , as way too much crap to sort out before I can do important things like that .
might run it NA 1380 first to blow the cobwebs off !
awesome.
interesting! so what class would my mini fall into with carbon boot floor and full width air box?
In theory mod prod upto 2000cc.
The airbox may be an issue at some events, but it wouldn't personaly bother me.
carl talbot
Member #: 1323
as usual with these things it depends on who you beat and whether they are miserable types .
In theory you are not allowed to modify the shell between wheel centres .
Ben H
Member #: 184
You can modify the shell between the hub centres, just not the unitary construction, there is a difference, subtle though.
mw3
Member #: 9590
Derby
This is good news,
I think The rules are also open to Interpretation, but the boot floor is a funny one like with the fibre glass front. Most people cut between hub centres on the front and the same in the boot.
I'm sure ill find out all the do's and fonts next year. I think in general people only have a problem with your car if you start winning
Matt W
On 14th Mar, 2012 mw3 said:
carl talbot
Member #: 1323
unitary construction takes too long to type one fingered !
but do enlighten us on the subtleties -
Unitary construction is defined as the chassis and bodywork as a single construction. Chassis is then further defined as the structure that supports the majormechanical components and bodywok as that in the airstreem.
Anything other than that is therefore not unitary.
Such things as the rear bins in a mini. and the rear seat, plus a few other bits.
I fancy doing a sprint in my car. I hear these are held at Llandow pretty often, this is only 15 mins from home for me
I'd like to see that!
Yes, there is a HSA round there every year at least. Not sure which other clubs riun one.
