| Home > Help Needed / General Tech Chat > using an injection fuel tank and pump | |||||||
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
9th Jun, 2005 at 02:34:41pm
ok chaps, i already have a injection tank in the car, but im using it with an external pump at the moment. I've blocked off the return temporarily to do this, but obsviously the breather is still open. Im now looking to use the injection tank pump as im changing engines and the external one isnt an option. what kit and setup would i need to do this? I'd obviously need a regulator which would handle a return, but which one would i use? My experiance of regulators, pumps etc is very limited. Any info would be usefull. :cool: I've seen the future and tbh its Pie
9th Jun, 2005 at 02:52:52pm
Really not sure what you're asking - or what/why you've been doing what you have - other than thinking you're nat-asp and have been using one of these little fuel pumps for carbs?
9th Jun, 2005 at 04:07:54pm
yep, im nat.asp at the moment and have converted my single point car to run on a carb. In the process of switching to carb, i fitted a mechanical pump and a few other bits as i couldnt sucsessfully get the carb'd engine running with the injection pump in the tank.
9th Jun, 2005 at 04:36:27pm
You need to use a turbo type fuel reg. Available second hand or still available brand new from Avonbar and others. This regulates pressure down from pump pressure to the 4 psi required for a carb. The regulator also has a hose stub that you pipe to the plenum. This allows the regulator to keep the fuel pressure above boost pressure. If using on a N/A car then leave this hose stub open to atmosphere, and you will be able to run your N/A engine with the fuel setup 75% ready for turbo use.
9th Jun, 2005 at 04:41:13pm
ok having read all relevant articles in the faq im still a little confused.
9th Jun, 2005 at 04:42:29pm
tom, would this solve the problem i described above? I've seen the future and tbh its Pie
9th Jun, 2005 at 04:46:46pm
At a guess that regulator isn't suitable for what you are trying to get it to do, probably it is not strong enough to hold back the powerful injection pump.
9th Jun, 2005 at 04:52:25pm
i didnt set it up, but i will now, i'll order a lo guage as per daves guide and see what i can do with it.
Edited by andeh on 9th Jun, 2005. I've seen the future and tbh its Pie
9th Jun, 2005 at 04:54:20pm
Set it up and see what happens first off........
9th Jun, 2005 at 04:56:24pm
i'll see what i get from playing with the regulator and a guage, cheers :) I've seen the future and tbh its Pie
9th Jun, 2005 at 05:10:59pm
No, Buy the minispares (or secondhand) regulator unit. that one you have is NOT suitable. On 17th Nov, 2014 Tom Fenton said:
9th Jun, 2005 at 05:35:52pm
you need a return!!!!
9th Jun, 2005 at 05:53:22pm
I'll ask around see if anyones got one for sale, is there any preference as to which make/brand to use?
9th Jun, 2005 at 06:07:58pm
£40 inc VAT for a brand new regulator sounds like a good deal to me. Old ones can have stretched diaphrams, which lead to other problems... Buy it, fit it, forget it! On 17th Nov, 2014 Tom Fenton said:
9th Jun, 2005 at 06:12:34pm
:cool: Cheers once again :cool: I've seen the future and tbh its Pie
