Home > Beginners Tech > Mini 8.4 disc brake driving flange removal.. annoying!
NickG
Member #: 7912
Australia oi oi oi!
Hi lads.
bit of a novice one *oh well*
im just swapping over my discs, but i cant remove the drive flange bolts from the old discs.
is there a trick? what way to they turn? they are so tight!!!!!
i'm thinking of walking down to shop so they can spin them of with a air tool.
shellspeed
Member #: 9580
Surrey
Probably rusted in to the cast iron. They should not be more than breaker bar can cope with. Clamp in in a vice and heat them up to crack the rust
NickG
Member #: 7912
Australia oi oi oi!
got it off heat! did the trick! still tight nearly shit my pants straining lol.
are they torqued up to a setting at all?
Chalkie
Member #: 9764
Northamptonshire.
I tighten them "Tight" with bit of lock tight bit OTT but gives me peace of mind
KLAS
Member #: 2380
Hamburg, Germany
57Nm
NickG
Member #: 7912
Australia oi oi oi!
thanks klas thats about 42ft lbs
i think every one struggles with these at some point, experience taught me to crack them off with the calliper still on and a helper on the brakes, same for the castle nut although i can do that with the wheel on too *happy*
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Use an impact screw driver, works for me.. Alan
Main Build
Upgrade to Turbo
That would work for Cooper S type which use a countersunk screw, but the 8.4" type use a hex head bolt, which is usually a LOT tighter than the countersunk screws ever are, as the wheel studs are on the disc of a Cooper S disc, meaning the wheel nuts clamp it all up, but on the drive flange of an 8.4", which means the 4 bolts have to transfer all the braking load.
Edited by Tom Fenton on 17th Dec, 2012.
nala56
Member #: 9661
ok Tom I got it wrong I was thinking it was cooper s disks.. Alan
Main Build
Upgrade to Turbo
