Home > Help Needed / General Tech Chat > ECU Options
Dr. jinG
Member #: 368
Roseville, CA (USA)
I'm told that the Haltech E6K is an ideal EMU for turbo-ing a Mini. However, what other options are there out there for engine management that will fire the injectors with every ignition pulse?
I'm worried about the cost involved with going the Haltech route. Will MegaSquirt get the job done? If so, any reputable "dealers" out there for buying one from?
1967 Cooper 's' Turbo build @ www.drjing.com
heres one
http://www.emeraldm3d.com/
On 11/06/2005 00:41:22 mini1071s said:
MS can do the single throttle body wet manifold injection
So can an SU...........
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
MS will still be easier to tune *tongue*
aELx
AlexF
aELx
Quarter to three on a saturday afternoon and Alex or should I say aELx is pissed already.........I don't know.......!!!!!!
hahaha, good old axelF
Mike
Member #: 107
Sunny Sussex
can we have a sticky with ignition maps for 998, 1275 etc and compressor maps?
Dr. jinG
Member #: 368
Roseville, CA (USA)
Thanks for the info, guys. Emerald is MUCH more expensive than the Haltech, and once I get a MegaSquirt AND the MegaJolt done, I'd be into it for almost as much as the Haltech, and a LOT more hassle. I'll just keep looking for a decent, used E6K...
Mike
Member #: 107
Sunny Sussex
u only need EITHER a megajolt OR megasquirt, saying that the megajolt only does ignition whereas the MegaSquirt does ignition AND fueling.
snowfruit
Member #: 557
Ireland
So if you're using a carb is there any need for the megasquirt?
Also, is it possible to adapt an ecu out of another model car?
Edited by snowfruit on 16th Jun, 2005.
Dr. jinG
Member #: 368
Roseville, CA (USA)
Mike, thanks for the clarification! I had thought that you needed one of each. MegaSquirt might be the way to go! Now, does if fire the injectors on every ignition pulse?
OK, I'll go trawl through the web sites and try to answer it for myself... *wink*
Mike
Member #: 107
Sunny Sussex
snowfruit... if your keeping the carb, go with a Megajolt, they cost about £75 ready built, but you'll need an EDIS system (EDIS brain, coilpack, leads and some sensors) you can probably grab those for around £40 off ebay or maybe cheaper from a scrappy.
Not sure if modifying an existing ECU is really worth it given the cost of the MegaJolt kit to be honest.
Jing, not sure about the injector firing as i dont use it, but i'm sure some others on here do. Sure they'll answer soon.
Dr. jinG
Member #: 368
Roseville, CA (USA)
Had a look-see, and it is indeed capable of firing injectors with every pulse! Pretty impressive bit of work, the more I read. I think I've found my EMU.
I'm now trying to figure out where to get the tuning interface for the Palm. That would be ideal for tuning. No lugging around a heavy laptop, just plug in the Palm I always have with me. Yeah, baby...
Mike
Member #: 107
Sunny Sussex
here u go :)
http://www.msefi.com/dload.php?action=category&cat_id=31
Dr. jinG
Member #: 368
Roseville, CA (USA)
Thanks, Mike, but I've been trying that link. I've contacted Roger about it. When I try to download, I get a 404 error (The selected File does not exist anymore
404 File Not Found: The File ./pafiledb/uploads/da615664b1379ab7099943586c43a75b.prc does not exist.). I don't see the screen shot, either! I'm hoping that there is another link I need to use, or that Roger can just mail it to me direct... The Palm would be the perfect tuning tool! I like it better than the DTEC (which uses a GameBoy as an interface, but is not a stand-alone system).
Mike
Member #: 107
Sunny Sussex
i downloaded it ok, installed it on my aging Palm IIIxe!
here, grab them from my server..
http://www.iqc.co.uk/efi/ms-palm.zip
http://www.iqc.co.uk/efi/palmmsns-v11.zip
http://www.iqc.co.uk/efi/ybas145b0.zip
Edited by Mike on 17th Jun, 2005.
Dr. jinG
Member #: 368
Roseville, CA (USA)
Awesome! Thanks, Mike. I got the first and the third, but the second one came up with an error (http://www.iqc.co.uk/efi/palmsns-v11.zip = The requested URL was not found on this server. ).
Mike
Member #: 107
Sunny Sussex
oops, missed an M, it works now
Dr. jinG
Member #: 368
Roseville, CA (USA)
Does indeed! Thanks, again, Mike. Do you know if I can install to my Palm and play around with it, before I give that a try and potentially screw something up...?
Mike
Member #: 107
Sunny Sussex
yes u can install it and play, but it'll complain it cant se the ECU, so u cant 'save' the settings.
Dr. jinG
Member #: 368
Roseville, CA (USA)
Awesome. Thanks, Mike! Looking forward to playing with it...
this is the map ive got on mine at the omoent
its from a trurbo mr2 running 8:1cr and upto 16psi of boost
but i havent really tried it yet just burbled up the road
Dr. jinG
Member #: 368
Roseville, CA (USA)
Hi Grey. Don't see any map...
ah balls, i think it must be saved in the format used by the ecu
Edited by Nic on 19th Jun, 2005.
nutter driver
Member #: 47
Not very sunny swanage
grey, where did you buy your mjlj from? kit form or ready built?
