Home > Help Needed / General Tech Chat > Lowered or Standard?
kappa
Member #: 9854
Hounslow, Middlesex
Hi all,
I just wanted to find out if I was to buy a set of adjustable shocks, there are 2 options avaliable:
1. Standard Height
2. Lowered Height
Now my question is, I will be looking to run Hi-Lo's, adjustable rear brackets & adjustable bottom arms and adjustable tie-rods up front, all bushes are uprated and the car is running on 7 x 10's.
But which shock do I choose, do I go for the lowered ones or the standard ones? Would the lowered ones make a big diffrence in how low my car can sit?
All help is really appreciated.
Thanks
Bobby
mossy2a
Member #: 9751
Derbyshire
Im not 100% but am pretty sure you have to run the lowered ones if you are lowering the ride height via hi-los. I think otherwise the std height ones are too long and for instance if you go over a bump, hill or something to make the wheel drop, the the knuckle or donut can come out of its seat.
maybe wrong though, but thats how my mind sees it.
kappa
Member #: 9854
Hounslow, Middlesex
Oh ok, thats sounds right, but again I am not 100% sure either
It depends how low you make it.
If your slamming it then go with the lowered ones. If your only lowering by a cm then you should be fine.
Mossy is correct the lowered dampera re really to reduce droop. although in theory ther will mean that the damper won't bottom out either.
At the front you can raise the height of the top damper mount as well.
kappa
Member #: 9854
Hounslow, Middlesex
I would like to slam the car to get it low, so looks like the lowered ones are the option.
Cheers for that
Jackamason
Member #: 10013
Hockley, Essex
I made the mistake of purchasing the standard ones as i thought you only needed lowered if drastically lowering it. I was wrong. My "standard" front ones bottomed out. The rears did not but when i jacked the car up the dougnut came off the subframe so i had to careful lower the car while positioning it each time.
Ive now changed the full set to the lowered ones and its perfect, bar the oil leaking from the adjustment knobs. (soon to be sent for a warranty replacement)
NB
Member #: 10097
you'll need lowered ones. I've just found that out the hard way (see my thread from the other day) and I've just ordered a set.
How far you lower a mini depends on how bad your spine is and/or how bad you want it to be
nala56
Member #: 9661
Sheffield South Yorkshire GB.
I fitted the lowed ones after having standed for two reasons one I wanted the car slightly lower and the other was I am running springs all round and the rear ones use to rattle because the travel on standed was allowing the radius arms to come away from the springs, thats why they rattled..
Main Build
Upgrade to Turbo
nala56
Member #: 9661
PS. Road holding and noise wise loads better.. Alan
Edited by nala56 on 3rd Dec, 2012.
Main Build
Upgrade to Turbo
kappa
Member #: 9854
Hounslow, Middlesex
So I think the lowered one are the best option for me, is there a big diffrence in what make I buy? i.e Gmax, Gaz, Avo, Spax etc?
nala56
Member #: 9661
I bought Gaz adjustable, Im happy with them is all I can say..
Main Build
Upgrade to Turbo
kappa
Member #: 9854
Hounslow, Middlesex
I was thinking about the sames ones, so thta sound promising, cheers
