| Home > Technical Chat > MJ mapping N/A | |||||||
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
6th Dec, 2012 at 09:00:38am
I hope someone can help, decided to change the standard dizzy on my mini to MJ with TPS.
7th Dec, 2012 at 06:41:35pm
Been looking for maps with TPS but to no avail. What the mind can conceive the mini can achieve
7th Dec, 2012 at 07:57:08pm
there is not many users running tps on here, those that do are likely to be well strung engines and expertly set up
Yes i moved to the darkside |
7th Dec, 2012 at 08:57:57pm
Been looking at it over the course of the week seems simple enough but for the sake of £15 going to convert MJ to map and then that opens the window to future mods What the mind can conceive the mini can achieve
7th Dec, 2012 at 10:33:55pm
ill have a dig about, if you pm tom fenton he may still have some, he supplies some mint stainless ones
Edited by Brett on 7th Dec, 2012. Yes i moved to the darkside |
65 Posts Member #: 8079 Advanced Member York |
7th Dec, 2012 at 10:50:01pm
Hey, if you go to MAP, I could send you a few maps to give you an idea/ starting point.
8th Dec, 2012 at 09:31:23am
On 7th Dec, 2012 Brett said:
ill have a dig about, if you pm tom fenton he may still have some, he supplies some mint stainless ones there we go best i have on file Cheers Brett, been using the search button and saw these but the post was years ago. :$ I'll drop Tom a PM and see what he's got, picking all MJ bits up today but think the trigger wheel is a weld on one so may need machined bottom pulley like in old posts by Tom. What the mind can conceive the mini can achieve
8th Dec, 2012 at 09:33:37am
On 7th Dec, 2012 smiffy_no46 said:
Hey, if you go to MAP, I could send you a few maps to give you an idea/ starting point. Some of mine wont be a million miles off your spec other than I run bike carbs rather than a 45 I mapped mine on a rolling road and its fairly simple once you get going. PM me if you want any more info, even just for a look. Cheers smiffy, PM SENT
going to do the conversion in the new year so just need a map to get mini running and to RR. What the mind can conceive the mini can achieve
8th Dec, 2012 at 08:59:29pm
if you get a TomF bracket it wont work with a weld on 36-1 ring Yes i moved to the darkside |
8th Dec, 2012 at 09:13:11pm
On 8th Dec, 2012 Brett said:
if you get a TomF bracket it wont work with a weld on 36-1 ring Pm'd Tom to see if he has both, 36-1 pulley and VR bracket. Off to pick up MJ tomoz so will be learning to connect and upload maps ready for next year. Just need to source a map similar to mini spec. What the mind can conceive the mini can achieve
29th Dec, 2012 at 09:23:33pm
Looks like I now have all the parts to convert to MJ.
29th Dec, 2012 at 11:08:29pm
Lee,
30th Dec, 2012 at 02:00:25am
Didn't Madmk1 run TPS on his old weber setup? |
30th Dec, 2012 at 09:29:00am
On 29th Dec, 2012 Tom Fenton said:
Lee, For a NA engine with a reasonably hot cam in then MAP will be useless no matter what you do, you need to rig it up TPS and then map the ECU to suit. The reason a lot of lads on here use MAP is that we need the density compensation for boost. But using MAP to sense load in your application will be shite I am afraid. Maybe not what you want to hear but TPS will be the better option for you. It seems everywhere I looked inc n/a are running MAP and no one seems to be running TPS. The MJ I have is TPS but converted it to MAP, only cost £12 so it's an easy change back as only removed the R3 resistor from the TPS. I've also not been able to locate a map for the TPS version for a mini :( What the mind can conceive the mini can achieve
30th Dec, 2012 at 11:10:26am
To be honest running a map you have found on the net is just asking for trouble, get it running on the megajolt, then take it to a rolling road that knows what they are doing.
30th Dec, 2012 at 11:55:25am
On 30th Dec, 2012 Tom Fenton said:
To be honest running a map you have found on the net is just asking for trouble, get it running on the megajolt, then take it to a rolling road that knows what they are doing. That's the idea, the base map is just to get to rolling road. Was thinking of copying the dizzy advance with a timing light through he revs till full advance of 32 degrees and put that in as a 2D map, totally defeats the object of MJ but I know the dizzy advance is safe, not running vacuum as on weber so it's quite easy. Then just download a map at rolling road. What the mind can conceive the mini can achieve
30th Dec, 2012 at 12:49:15pm
Hi there Mate, I had run my weber with a TPS, as for a base map, I just loaded the 1380ccMAP, map that was on the disk you get with the MJ, then I drove to minispeed under 40mph all the way JOB DONE! I have started posting on Instagram also my name on there is turbomk1golf
30th Dec, 2012 at 01:32:49pm
The advice on the autosport labs website if using map would be to put an inline box to help equal out the signal. A bloke in our local club used a small plastic fuel filter as it was about the correct size. His engine did work well but then he was a flat out or nothing kind of driver.
30th Dec, 2012 at 03:45:58pm
On 30th Dec, 2012 gr4h4m said:
The advice on the autosport labs website if using map would be to put an inline box to help equal out the signal. A bloke in our local club used a small plastic fuel filter as it was about the correct size. His engine did work well but then he was a flat out or nothing kind of driver. Good luck, once you go mj and get it mapped you won't go back Mini only really built for runs and of course MITP so not used daily. Think I'll go for the box method and hide it behind the dash with MJ. What the mind can conceive the mini can achieve
30th Dec, 2012 at 03:46:07pm
30th Dec, 2012 at 03:46:08pm
30th Dec, 2012 at 09:13:20pm
TPS is used by all the NA 16v guys since they tend to use ITBs and fairly hot cams. I know when I tried to get a decent MAP signal from mine, I gave up and tuned for TPS, it was the ony way.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
30th Dec, 2012 at 09:30:00pm
You have probably seen the maps on Autosport labs but at least here is a link for future people finding this thread looking for different maps for their set-up being it NA or charged:
Dazed and Confused.... |
31st Dec, 2012 at 09:57:33am
Hi all, it seems that there are mixing feelings on weather to go TPS OR MAP.
