| Home > Help Needed / General Tech Chat > Confirm My Smoking Diagnosis | |||||||
7th Dec, 2012 at 10:37:23am
The Sprint has a terrible smoking habbit, here are the symptoms
7th Dec, 2012 at 10:40:12am
I had exactly the same at Avon one year mate, was the oil seals in the turbine.
7th Dec, 2012 at 10:40:43am
Ref: oil return, in the past I have found that unless it is severly undersize or restricted, it will smoke when cold and then stop once the oil warms up and thins out.
7th Dec, 2012 at 12:03:05pm
Yes you have it in one wil your prognosis is right,
7th Dec, 2012 at 01:29:50pm
Has a quote for a rebuild £300, that twice what the turbo cost!!
7th Dec, 2012 at 01:37:37pm
Do you have a restrictor in line for the oil feed. Sure I have read somewhere that BB turbo's tend not to like much more than 25psi of oil pressure. Perhaps this could have contributed to premature seal failure. If something is worth doing, it's worth doing half of. |
9th Dec, 2012 at 09:36:27pm
when i was having my smoking issues (found out to be the oil return entering the engien below the oil level) it caused smoking at idle, never right away, and regardless of hot or cold. if ran for a while eventually the turbo oil seals gave out. Would defo fit a restrictor to the oil feat for a BB core, but be carefull as some cores have restrictive orifices in the inlet in the core. turbo 16v k-series 11.9@118.9 :)
