Home > Technical Chat > Decked blocks
bakker110
Member #: 9367
Derby
I'm just wondering if anyone could help out working out whether my block that is decked to 21253 pistons would work with omegas forged 18cc pistons or if they would sit too high. Ideally I don't want to have to get a new block but if it doesn't work I'll have to.
Thanks
Alex
Member #: 1851
Woolavington, Zummerzet
21253s are hugely tall - I had to have .045" lopped off the top of mine !
bakker110
Member #: 9367
Derby
Did you fit the omegas then?
Most aftermarket pistons I have installed sit between 0.060" and 0.040" down the bore on a standard height block, those include 21253's, Minispares Mega's, Accralite forged and Oldschool Omega's
My 0.020" cast omegas where 0.040" down the bore. I had 0.030" taken of my block to get the CR sensible.
I think the compression height on those two should be quite similar. You could have the pistons turned in a lathe though, if a problem.
Craigie-B
Member #: 9468
Wootton Bassett
why do the pistons sit so far down the block?
It makes it easy for the amature engine builder to set the compression ratio to suit the cam with off the shelf parts.
any decent engine builder would set the pistons flush with the top of the block and set the compression ratio to suit the cam by machining the head to suit.
how much has come off the block to start with ?
those std crown heigh omegas sit 0.030" down the bore if the block deck is standard ?
if you are in the deep stuff you could always get shortend crown height pistons for the same price
bakker110
Member #: 9367
Derby
I don't know exactly how much has come off the block just that it is flush with the pistons. Which are 21253's.
