| Home > Help Needed / General Tech Chat > Change from servo to non servo | |||||||
12th Jun, 2005 at 11:29:48am
Im looking to lose the servo powered master cylinder to free up some under bonnet space. |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
12th Jun, 2005 at 12:19:45pm
i dont know if this is right, but my thinking on the matter is, if you do end up with too much braking at the rear, then why not simply fit a in line bias valve? seems to be ideal solution to me, a helluva lot easier, albeit a bit more expensive.
And on the 7th day........... God created turbochargers! |
12th Jun, 2005 at 03:19:48pm
Dan make bloody sure the master cylinder is good! Personally I would never trust something as important as a brake master cylinder out of an old scrap car.........it might work now, but how long till it gives out??? At the MINIMUM strip it out and rebuild it with new seals! Think about it buddy, safety first and all that. They're not that expensive new compared to your life?
Edited by Tom Fenton on 12th Jun, 2005.
12th Jun, 2005 at 08:29:56pm
im trying to think this one out, to reduce the rear locking up when you stamp on the pedal you want larger rear cylinders?
12th Jun, 2005 at 09:11:55pm
I think it's 1/2" rears for discs and 3/4" rears for drums
12th Jun, 2005 at 09:34:25pm
On 12/06/2005 20:29:56 greypride said:
im trying to think this one out, to reduce the rear locking up when you stamp on the pedal you want larger rear cylinders? I wrote a calc on this sometime ago in a thread. I've had a look but I can't find it. If anyone knows where it is can they please post a link!
12th Jun, 2005 at 11:14:30pm
yes you did!
12th Jun, 2005 at 11:17:13pm
Thanks for the advice!
12th Jun, 2005 at 11:36:21pm
daa daa: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4647
12th Jun, 2005 at 11:37:38pm
Grey- can you post me a link to that thread if you know where it is? (D'OH beaten to it, cheers mate!)
12th Jun, 2005 at 11:42:26pm
for certain i would see what happens when you change the master cylinder, the bias valve idea was more of a way to save you changing the wheel cylinders. i changed to front discs on my 76 car and was told i would need to change the rear cylinders the maintain the balance, i never bothered, its always been fine!!! And on the 7th day........... God created turbochargers! |
