| Home > Wanted > Diff pinion | |||||||
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
17th Dec, 2012 at 05:36:50pm
Has anyone got a twenty tooth diff- pinion to suit a 59 tooth crown wheel for sale please?. Alan Main Build
17th Dec, 2012 at 07:05:49pm
If possible i'd always fit crown wheel and pinion as a pair. Fitting two used gears together that may have worn differently it is likely they will whine.
17th Dec, 2012 at 07:08:08pm
Not quite the same ratio, but I have 3.1:1 cw&p available if required. Edited by minimole23 on 17th Dec, 2012. On 7th Oct, 2010 5haneJ said:
17th Dec, 2012 at 09:52:21pm
I agree with you tom but some times if you cannot get a pair its the next best thing, would buy the pair if anyone has a pair for sale.. Alan
On 17th Dec, 2012 Tom Fenton said:
If possible i'd always fit crown wheel and pinion as a pair. Fitting two used gears together that may have worn differently it is likely they will whine. Main Build
17th Dec, 2012 at 09:55:37pm
Thanks for the offer mate but I already have that ratio need the 2.9 because im running 10" rims and want higher ratio.. Alan
On 17th Dec, 2012 minimole23 said:
Not quite the same ratio, but I have 3.1:1 cw&p available if required. Main Build
