Home > Help Needed / General Tech Chat > wiring loom help?
ian_mini
Member #: 485
Hi i currently have a bare shell that I will be putting a turbo engine in, but am wondering what to do about a wiring loom for it? i've been told to get a custom one made but at a cost of ?200, will this save me a lot of ball-ache or not?
thanks,
ian
nto really, just start with a standard one,
i use a standard mini loom
the ecu is on a seperate loom i did myself and to be honest was a piece if piss
pot_dan
Member #: 326
bradford, west yorks
i rang auto sparks and its 160 quid for my front loom from bulkhead forward i will be fitting that and adding what i need.. 200 for a custom loom sounds cheep tho?
Dan
http://turbominis.co.uk/car/105/
i'm still trying to fit my standard one, what a cunt of a job!!
ian_mini
Member #: 485
i'm not having an ecu on mine, from minispares looms are only £110 ish aren't they?
For the custom loom they start with the normal mini loom (priced above)
i was told that you tell them what your fitting gauges etc and position of them all, and it all comes braided with a new style fuse box?
my front and rear loom was from minispares its a real top quality item fitted lovely
alex why you having probs i thought it was an easy job
Carl
Member #: 95
liverpool-on-sea
my looms currently set out on my dining table whilst im hacking it and modifing it to suit my car. surley it cant be that hard to find a standard mini loom and fit that maybe even unwrap it bit by bit check for breaks etc and re tape it.
the only additions you need to a standard loom is for your fuel pump and make sure you have a 12volt supply to your coil and these are not difficult.
*smiley*
ian_mini
Member #: 485
yeh i wouldnt have thought it was a massive task and i could do without spending 200 really,
none really come up on ebay that i've seen, i guess its probly a case of looking in scrappys?
what years the car?
because i've got two different looms, and they're all chopped and nasty. :/
ian_mini
Member #: 485
wolfie are you talking to me? if so it's a bare shell on a 71 plate!
i have a pre 78 front and rear loom cant remember what its out of may have been the one that was in my original car befor it was reshelled or it could be a van one (rear is longer) but looks in good nick
give me a pm if your interested and ill dig it out and make sure its pukka
Edited by wolfie on 15th Jun, 2005.
Nicky
Member #: 333
Tadley, Hampshire
It might be cos he hasn't _actually_ started it yet *laughing*
HA HA HA HA!!
Dropped in it well and truly!!!!
