Home > Wanted > Some bits you may have lying about..
I am looking for some bits for a bit of a side project, so let me know if you can help me out.
This is for 2 doors, I am looking for numbers:
,10,11,6,7,
Also:
Vac hose , banjo with bolt for the servo
steering cowling for the twin stalks
tank strap
gear lever gaiter and ring
3 clock speedo set
clubman grille badge
Number plate lamp mk3 on
Interior lamp
9,11,12,13 all for a clubman 28,36,
Edited by madmk1 on 22nd Dec, 2012.
jonny f
Member #: 9894
Dorking
I've got a few of those bits i don't need laying about.
steering cowling for the twin stalks. mk3 one yea?
11, 22, 18 top drawing
Will have to double check though, as its just of the top of my head.
Tip Top! pm me when you know mate and what you are looking for them.
simon.
Also I need 4 Seat brackets.
Thanks simon.
Edited by madmk1 on 19th Dec, 2012.
dev 11
Member #: 9393
stoke on trent
Thanks simon.
i can sort you those out mate, will find them in the morning
cool mate pm on its way.
t@z
Member #: 452
Chester, UK
if ur having trouble si mosses is ur place to go. straight down m3>a316. means shops prices though
www.twitter.com/lilpinkiy
I know mate, but I am on a very small budget
Got a couple of 10 (top drawing) that have your name on them.
I should have most of the door bits. Will have a look in the next few days. remind me though.
Have sorted most of this lot, but John showing up and Dad duties got in the way. Will dig the rest out tomorrow and post on Sat.
22,18,15,16,44
6 - check strap - probably
7 - pin - probably
35 - boot catch - probably.
35 - boot catch
Thanks Andy, for having a look for me, is there all the stuff for 2 doors?
simon.
Good excuse to shift the rotten doors from down the cellar and onto the scrap pile.
Yep. assuming left and right sides...
yes mate i have 2 bare doors needing all the bits.
kcchan
Member #: 8853
Might have a tank strap if I can find it Simon
O that would be good mate is it for the big tank?
Thanks simon.
kcchan
Member #: 8853
Hmmm, not sure. I'll dig it out in the next couple of days and measure it for you.
22,18,15,16,44
7 - pin - probably
Got all that packed up and ready to go, except for the check strap clevis pins. Will be in the post tomorrow.
Top man
Just updated, thanks for your help so far lads.
I sent you a pair of number 6's.
Andy thats one less thing to look for then thanks.
