Home > Help Needed / General Tech Chat > optimum engine temperature
After being surprised earlier in the year to be informed that running the engine at 74 degrees is a bit old hat now most of us are running unleaded fuel I was wondering what thermostat I should be running on a N/A 1380 for which maximum power is desired - sod fuel economy.
I am about to fit my thermostat and are am curious about which I should fit 74, 82 or 88 degrees.
James
ditto
Cheers. Should be ready for the first start soon following the rebuild. *happy*
The cooler stat will be better for power and it will see the engine more resistant to detonation.
That applies to any engine, old school, new school, or anywhere in between.
I run an 88, but it never gets to 88 unless in traffic.
i have an 82 stat in the mini but also a switch able bypass for this reason-
the volvo is 92 deg apparently this is the ideal temp for unleaded
74 degrees for n/a
welshdan
Member #: 1111
s wales
i run a 74 in my turbo. it runs super cool with the min-its alloy rad, doesnt really go over this temp in traffic or after giving it a bit of stick...
i will be using the same on my new engine build
