| Home > Help Needed / General Tech Chat > fuel supply problem | |||||||
![]() 323 Posts Member #: 41 Senior Member |
23rd Dec, 2003 at 12:54:18pm
im trying to start the engine for the first time, but it doesnt want to know. i have fuel to the carb ok, at around 5psi, there is fuel in the fuel chamber, but it doesnt seem to go anywhere from there, the plugs dont smell of petrol at all, i know there arent ay blockages in the pipe that the jet holder is located around as i blew through it, any ideas why it isnt reaching the head? cheers A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
23rd Dec, 2003 at 02:04:10pm
blocked main jet?
AlexF |
23rd Dec, 2003 at 05:55:12pm
ive had the jet out and cleaned it up and that didnt seem to sort it, im thinking of taking off the vacumm pipe on the inlet manifold to see if i can see fuel run in the inlet manifold, do you think (if there was any fuel there) if you would be able to see if flow? A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
23rd Dec, 2003 at 08:33:23pm
The SU is so simple, there are only a few things that can cause problems like this.
Edited by turbodave16v on 23rd Dec, 2003. On 17th Nov, 2014 Tom Fenton said:
23rd Dec, 2003 at 11:22:28pm
Cheers for the pointers dave, trying to answer all of them. i have got oil pressure, as i connected up the pressure gauge and just cranked the engine over without the plugs in so it turned freely, got good oil pressure, more than 50psi.
23rd Dec, 2003 at 11:28:59pm
The anti run on pipe is the one on the side of the carb near the fuel in pipe.
24th Dec, 2003 at 12:46:35am
The anti-run on pipe is the one around 3/4" forwards of the fuel inlet pipe on the same side and same orientation. If this is not sealed, you will never start the engine!
Edited by turbodave16v on 24th Dec, 2003. On 17th Nov, 2014 Tom Fenton said:
24th Dec, 2003 at 10:25:31am
thanks lads, yeah i have a timing gun. i believe my engine to be from the mk1 metro turbo which, i think already has the run on pipe blanked off as i only have two connections on the carb, the fuel in, and that link pipe that loops around from the side of the carb to the flange of the carb. i'll have another go today at timing it in, but i dont think i will gain much as i have noticed a water leak between the head and the block by the engine ident plate! which means i think the head will have to come off and be skimmed! destined not to have this car on the road A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
24th Dec, 2003 at 11:34:12am
What was te fault in the end with your crank / flywheel? Team www.sheepspeed.com Racing
) fit the other leads in the order 1-3-4-2 from your reference lead (no.1)
