| Home > General Chat > Electric issues | |||||||
106 Posts Member #: 2135 Advanced Member plympton, plymouth |
5th Jan, 2013 at 04:50:49pm
388 Posts Member #: 442 Senior Member Manchester |
5th Jan, 2013 at 06:51:54pm
If you put the clamp on your brake pedal? If something is draning the battery, what i normally do is start pulling fuses until the amps go down. Then you know what circuit is at fault. |
336 Posts Member #: 9941 Senior Member Derby |
5th Jan, 2013 at 06:54:05pm
Try disconnecting the stereo |
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
5th Jan, 2013 at 08:21:03pm
I had this problem with an old mini years ago.. Had to carry a spare battery around incase I got stuck! Never really got to the bottom of it after checking everything, very frustrating!!
5th Jan, 2013 at 08:40:01pm
Pulling fuses is a good idea but check the condition of the battery cable too. I had this a few years back and it turned out the cable had a minor short.
5th Jan, 2013 at 09:34:38pm
That was prob the problem that I had on mine years ago, never considered the cable itself. Well I was only a pup at the time...
5th Jan, 2013 at 09:36:43pm
Disregard that last part, was thinking of something else lol |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
5th Jan, 2013 at 10:23:59pm
are you sure the altenator is actually charging it?
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
5th Jan, 2013 at 11:42:44pm
yep battery reads 14+v when running
On 5th Jan, 2013 Craigie-B said:
are you sure the altenator is actually charging it? Should be around 14v with the car on |
5th Jan, 2013 at 11:49:43pm
On 5th Jan, 2013 Rob Gavin said:
Pulling fuses is a good idea but check the condition of the battery cable too. I had this a few years back and it turned out the cable had a minor short. |
5th Jan, 2013 at 11:51:50pm
On 5th Jan, 2013 evad1980 said:
Sounds like a direct short to the body of your car, as Rob says check your battery cable. Also, with the battery charged, put a voltmeter across the negative terminal and to earth (the minis shell)... If you get a voltage you have a short. |
5th Jan, 2013 at 11:58:19pm
For a start I would not trust a clamp on ammeter on low current 12v. Disconnect your battery main pos cable, set an ammeter to highest current range (usually circa 10A) then make sure everything possible is off, connect your meter between battery terminal and main cable. This gives your idle current draw that should be very low. If not something on the car is consuming power and flattening your battery, so then it us a case of unplugging things to see what us the culprit.
6th Jan, 2013 at 01:06:02am
Im with tom on that. The Clamp ones arnt the best. A proper ammeter will tell you exactly what draw is on the battery. Make sure you set it to amps and that the leads are in the correct plugs on the meter. Ive accidentally blown a couple up in the past.
6th Jan, 2013 at 12:39:35pm
On 5th Jan, 2013 Tom Fenton said:
For a start I would not trust a clamp on ammeter on low current 12v. Disconnect your battery main pos cable, set an ammeter to highest current range (usually circa 10A) then make sure everything possible is off, connect your meter between battery terminal and main cable. This gives your idle current draw that should be very low. If not something on the car is consuming power and flattening your battery, so then it us a case of unplugging things to see what us the culprit. could this be the issue - main +ve cable from battery joined together but bolted to floor - with the meter on the other side I can sometimes with a poke about get 0.1v,
6th Jan, 2013 at 04:16:11pm
Are you saying that between earth and this terminal you only measure 0.1V? If so, this is your problem as it means they are at the same potential. Either way, an unsheathed connection sat in the footwell is not a good idea. |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
6th Jan, 2013 at 04:38:44pm
that maybe your problem Edited by wng691s clubby on 6th Jan, 2013. Done now needs redoing lol |
6th Jan, 2013 at 04:54:48pm
Are those fuel lines aswell? |
1300 Posts Member #: 829 Post Whore essex |
6th Jan, 2013 at 08:23:55pm
On 5th Jan, 2013 mr_incognito said: im lost in what you are doing first off you need a multimeter with two leads on it set the meter to amp remove the neg lead from the battery put the red lead of the meter to the battery neg post on the battery now the batery lug which is on the earth lead put the black wire of the meter to it the reading will jump to start off with and then settle this is the current drian (DO NOT SWITCH THE IGN ON YOU WILL BLOW THE FUSE IN THE METER )start off with live fuses with the ign off and pull the plug out of the alternator
I have some electrical issues i am struggling with, not something i enjoy doing or know much about. The battery on my new mini drains overnight. borrowed a multimeter, the type that clamps over the cable and reads amps. the +ve cable from the battery that goes up the car reads 2.8 amps when nothing is turned on. If i put the clamp on my break pedal it reads 5 amps. does this mean i have a live shorting somewhere/bad earth? cheers Liam 1293 Turbo mini
6th Jan, 2013 at 09:34:03pm
That is the positive cable from the battery I'm guessing??
6th Jan, 2013 at 09:51:49pm
On 6th Jan, 2013 evad1980 said: i have seen a lot of kit cars do this with exhaust rubbers using it as a terminal block
That is the positive cable from the battery I'm guessing?? Disconnect the connection you have pictured. Bolt the two ends of the cables back together through the lugs but not to the car floor. Insulate it completely... Retry your tests. The picture shows (to me) that there is some insulating material under the connection, a rubber stop or something but the nylon nut and bolt will create a short. Make sure the connection does not touch the car floor.. Or any other part. 1293 Turbo mini
6th Jan, 2013 at 10:35:21pm
Ya I can understand that.. But the rubber is pointless unless you use a non conducting nut & bolt i.e completely nylon... Otherwise you may as well bolt it to the floor without the rubber.. |
6th Jan, 2013 at 10:46:53pm
those exhaust rubbers dont have the bolt all the way through, its a bit of rubber with a stud on each end...
6th Jan, 2013 at 11:11:43pm
Ah that would make sense.. |
