Home > Help Needed / General Tech Chat > Would these work for my turbo set up
kappa
Member #: 9854
Hounslow, Middlesex
I am looking at a set of pistons, would these work for a turbo set-uo or is it more for NA engines
http://www.minispares.com/product/Classic/....aspx|Back%20to
Sorry for not knowing your project intimately, but what sort of power/boost are you planning?
Most pistons will be ok with moderate boost (assuming suitable CR, fuelling and ignition control).
Moderate = <10psi
kappa
Member #: 9854
Hounslow, Middlesex
Sorry I should of explained more clearly.
I am running a hybrid GT15/t2 turbo with a 360 degrees thrust bearing, with a uprated actutator, mirage manifold, turbo phils head with 24cc chambers, hardened valve seats, double springs ect & a Megajolt system. The block is a standard metro turbo at the moment and the gearbox is a standard metro turbo, but with a 4 pin diff, straight cut drop gears and a 3.1 final drive. Fuelling will just be the standard turbo carb, with a metro turbo fuel reg and a facet electric fuel pump. I am running a dump valve off the plenum and a intercooler as well
I am not sure what sort of PSI i should be running, as this is my first turbo build.
Hope fully this helps
Bobby
Edited by kappa on 10th Jan, 2013.
I personally wouldn't use em in an N/A engine never mind a forced induction one.
Do yourself a favour and buy some 10cc Omega's from MED and forget about these.
kappa
Member #: 9854
Hounslow, Middlesex
Thanks for the advise John, I see alot of you guys uasing these, I think I will spalsh out on a set of these MED ones
Also, dump the facet fuel pump. It's not up to the job.
kappa
Member #: 9854
Hounslow, Middlesex
Apbellamy what will be a good electric pump to use?
The Bosch efi pump similar to the one the metro turbo etc used
kappa
Member #: 9854
Hounslow, Middlesex
Ok thats a big help cheers
Or an MPI fuel tank as it has a 3bar fuel pump in it.
kappa
Member #: 9854
Hounslow, Middlesex
I would love to use the MPI tank, but I am doing a conversion in my clubby estate, so MPI will not work
Alex
Member #: 1851
Woolavington, Zummerzet
I've seen too many of these break up in NA engines to even start thinking about boost.
My cast omegas have taken more det and boost than you would ever believe
kappa
Member #: 9854
Hounslow, Middlesex
what is better, 10cc or 18cc
depends what cr you want...
i would take the 10s and mod the head to suit the cr the crown is chunky as fook in my 10s and i think that helps them with the abuse they get they sit 0.5mm down a std block also so you can use that to lower the cr at the expence of squish
Jawd
Member #: 10212
Sleaford Lincolnshire
I am going to use the 18's on my build but I have my reasons,
Omegas are the best blown pistons for sure
kappa
Member #: 9854
Hounslow, Middlesex
I am not sure what CR I should be aiming for, I want to use the car as a daily drive and some track days if this helps to give me a indication of what CR I should be looking at to achieve
