Home > Help Needed / General Tech Chat > Question on bores
kappa
Member #: 9854
Hounslow, Middlesex
Hi all,
I just wanted to get some advise. Basically I bought a turbo block to do my conversion, so I have stripped my turbo block down, all pistons out, I was looking at the bores. They look quite good , no scoring or pitting in the bores only a bit of surface rust.
Now my question is what is the best way to clean the bores, before putting the pistons back in?
Bobby
A hone,
check for any signs of a step at the top of the bore caused by the top ring
http://www.diseno-art.com/products/tools/cylinder_hone.html
kappa
Member #: 9854
Hounslow, Middlesex
Should I use one of these:
http://www.machinemart.co.uk/shop/product/...tive-hand-tools
thats the job.
kappa
Member #: 9854
Hounslow, Middlesex
Excellent cheers for that info
Take it to a machine shop, you will just fook it up. Cost me £20 last time i had one done.
kappa
Member #: 9854
Hounslow, Middlesex
Yeah was thinking about that as my hand may slip when doing and I probably will fook it up, rather just pay £20 to someone to get it done
I had a go in a block that wanted boring. It didn't go well.
It's the sort of thing that needs to be done properly otherwise you will find yourself with your engine in bits again
Edited by apbellamy on 13th Jan, 2013.
your not far from Vmax could try him, if he dosent do it in house he should be able to hook you up...
http://www.vmaxscart.co.uk/
failing that, theres rob walker over in oxon
http://www.robwalkerengineering.co.uk/
Also theres ML motorsport near gravesend (AC Dodd), they have a very good rep but I know for a fact they just use a hand hone.
http://www.mlmotorsport.com/index.php?opti...id=15&Itemid=36
kappa
Member #: 9854
Hounslow, Middlesex
Thanks a lot Joe, that is a big help
i would pay for a shop to do it its not the cleaning the bores thats the problem its the shape of 'scratches' that the honing leaves bohind, it needs to be that shape to promote the rotation of the piston rings
I'd use a machine shop til, but if doing it myself, I wouldn't use the hone mentioned above. Use a flex hone.
